pennyporsche
Hi Loren,
If you could ever so nicely help me with my radio code I'd appreciate. Thank you very much!
also, the digital backlight of the radio is broken so the first letter of the serial number I can't fully read but i think it's either an X or K? The rest of the digits I know are correct.
Becker 1
4462
# X5025042
Share this post
Link to post
Hi Loren,
Becker 1
4462
# X5025042
Try 5491
Share this post
Link to post
Really hope you can help. Many thanks! Here is all the info:
Becker
CDP2081
4462
SN-2501186
24/99
Edited by lunchbox911
Share this post
Link to post
Becker
CDP2081
4462
SN-2501186
24/99
Try 8476
Did not work. Any other suggestions?
Share this post
Link to post
Becker
CDP2081
4462
SN-2501186
24/99
Try 8476
Did you follow the procedure in the Lost Radio Code FAQ to get the serial number?
If not, please do and get the correct serial number.
Share this post
Link to post
Becker 1
CDP 2081
Type 4462
Seri 25011860
24/99
Gali 00
I see I originally left out the ""0". Sorry about that.
I'm in my car typing this directly from screen. Thank u much for the help
Share this post
Link to post
Becker 1
CDP 2081
Type 4462
Seri 25011860
24/99
Gali 00
Try 0517
Share this post
Link to post
CDP-2081
Becker
Type 4467
Ser # Y5025579
carrera 6/00
I need a really codeee ,i drive with out musicccccc
Thanks!!!!!!!!!!!
Try 9276 ..............
let us know how you get on :)
Share this post
Link to post
Thanks but i doit before 2 days, and nothing :(
I'm confused... Have you tried code 9276 before, and it has not worked?
Share this post
Link to post
Yes, i doit...and not worked!!!!
OK.... firstly the code given is the correct original code for your serial number.
You need to check your serial number, from the label attached to the metal casing.
I suspect you have provided the correct serial number, and it is probably the case that the radio has been re-coded to another code in the past.
The code is stored in eeprom 24c02, and if you have an eeprom programmer to read the memory contents, I can provide a code from this... If you don't have the equipment to read eeproms, then a radio decoder in your area will be able to help you..
Cheers.
Share this post
Link to post
Thanks Bruce201 for your help, but i havent reader to read the eeprom,the s/n is correct from the label,and from TP...
but , but nothing....
Share this post
Link to post
Just one other thought... the radio is allowing you to enter code?, i.e four stars appear like **** and it is not showing 'WAIT"
Sometimes radios will 'time lock', in which case you need to leave radio powered on with ignition to 'accessory' position to reset.
Failing any of those problems above... definately a job for the radio decoder.
Sorry
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
