pennyporsche
Sorry if I wasn't clear - I don't have the radio code (I'm not the first owner), and I want to have it on hand before I attempt installation of an iPod cable.
--scott
Anyone still watching this topic? I have a 2002 Boxster base. The radio (CDR-220) works fine, but I'd like to attach an aux/iPod cable and the instructions say to disconnect the power to the head unit during installation. The menu reports serial number 25014726.
--scott
Please post your question in the appropriate forum - this thread is for Lost Radio codes only.
Share this post
Link to post
--scott
--scott
Yes, I understand - we can not get your radio code without your radio serial number - please read the FAQ as requested.
Share this post
Link to post
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
It has been saying "wait" for a day. Anyway to hack into it to put the code in while it is in "wait" mode
Share this post
Link to post
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
Did you read the FAQ? I think not...
"I get a WAIT in the display - what do I do?
You have to wait 1 hour - with the radio on and ignition switch on (or the car running)."
Your code should be 1321
Share this post
Link to post
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
Thanks, I'll turn the ignition on and give it a shot.
I read the instructions, but don't see a FAQ and don't know where it would be first day on this forum.
Share this post
Link to post
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
Lost Radio Code - FAQ
Share this post
Link to post
CDR-220
Type 4462
Serial 25014726 (Z50147526? It looks like a 2 on the display, and I haven't pulled the radio to check the back)
Share this post
Link to post
CDR-220
Type 4462
Please read the Lost Radio Code FAQ for how to double check the serial number through the display.
If you think you read it correctly then
Try 1304
Share this post
Link to post
Im hoping someone can help, I don't have the code
CR-220
CDC-3
Y1060480
Matt
Please use the Lost Radio Code FAQ to obtain the correct serial number.
If you did and the number listed above is correct then try 8930
Share this post
Link to post
2001 Boxster
CDR 220
Model # BE 4462
Serial # 15088358
Many thanks; your time is greatly appreciated.
Jäger
Share this post
Link to post
2001 Boxster
CDR 220
Model # BE 4462
Serial # 15088358
Jäger
Try 9520
Thanks Loren that was a good code.
I have a 2001 Boxster with over 219,000 miles on it. I have owned the car since 2005 and perform most of the maintenance myself, this was the first time I have disconnected the battery. Thanks again.
Jäger
Share this post
Link to post
help please
cdr-220
Becker 1
type 4462
serial number 25012148
Try 4398
Thank you so much! It worked perfectly.
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
