pennyporsche
Hi, I just purchased a black 2001 Carrera 2 aerokit, and after replacing the battery with a new unit, I am in need of a radio code.
It's a CR-220 radio
Becker 1
Serial # 15040234
4363
24/99
Thanks in advance!
-Todd
Share this post
Link to post
It's a CR-220 radio
Becker 1
Serial # 15040234
4363
24/99
Thanks in advance!
-Todd
Try 2625
Share this post
Link to post
If those don't work and you have access to a DME reader, I believe it's listed under Vehicle Data
- Old Blevins
I replaced my battery a few months back and finally had the time to hook up the durametric since I remember seeing the code under vehicle data. I put it in and it doesn't work. So, they wasted time to put the WRONG code into the DME? And of course I have PCM so it looks like I have to bring it to the dealer in order to get the code from it, correct? I wonder what they are going to charge for that? Or I can just drive around without the pathetic sounding radio or outdated NAV :) :)
edit: Didnt realize I was in the boxster section. I have an '01 996TT
Edited by D_Nyholm
Share this post
Link to post
- Old Blevins
From the Lost Radio Code FAQ...
Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC.
Share this post
Link to post
I need help With a Radio Code please.
I bought a 77 porsche with a 2000 Boxter Radio installed. Dealer cannot give me the code b/c I don't have a VIN #.
If there is a way anyone can get a code, it would really help.
Info:
2000 Porsche Boxter Radio
CR-210
Model-No: BE2182
Serial-NO: W5011655
EC: 102
993.645.117.01
Share this post
Link to post
Info:
CR-210
Model-No: BE2182
Serial-NO: W5011655
EC: 102
993.645.117.01
Try 4539
Share this post
Link to post
Info:
CR-210
Model-No: BE2182
Serial-NO: W5011655
EC: 102
993.645.117.01
Try 4539
Thank you Very Much!! It works.
This saves me from getting a new radio.
David
Share this post
Link to post
I have a 2000 911 Cab 996
CDR-220
Radio Serial number is
Y5038937
Can you provide me my code. I am about to change the Battery
Thank You
Try 3642
Thank you for the very quick turnaround. I will let you know how it goes
The Code worked great...
Share this post
Link to post
Hi :) I have a 1999 porsche boxster that due to maintenance the battery got disconnected serial number is W502 1935.
Thank you sir
SquishO90
Share this post
Link to post
Well, I got the radio refurbished. Looks good but I haven't got the code. It came from my new to me 1999 Boxster.
CDR 220
BE 4462
W5006378
Thanks very much!
Share this post
Link to post
CDR 220
BE 4462
W5006378
Thanks very much!
Try 3141
Share this post
Link to post
Hello, I have a 2001 911 Carrera I changed the battery and lost the code.
Becker1 CDR 220
Type 4462
SER Y5040678
24/99
Thank you!!!
Share this post
Link to post
CDR 220
BE 4462
W5006378
Thanks very much!
Try 3141
Worked! Thanks very much.
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
