pennyporsche
Greetings!
We have a 2000 911 Carrera 4. We'd sure appreciate an unlock code for the stereo.
The stereo info is:
CDR-220
Model: 4462
Serial: X5036708
Thank you in advance for any help you can provide.
Tery
Edited by temilson
Share this post
Link to post
Greetings!
The stereo info is:
CDR-220
Model: 4462
Serial: X5036708
Tery
Try 0943
Share this post
Link to post
Greetings!
The stereo info is:
CDR-220
Model: 4462
Serial: X5036708
Tery
Try 0943
Thank you so much! It worked like a charm!
Share this post
Link to post
Hi Loren,
I disconnected the battery when installing fresh seats....
Becker 220
Type 4462
Serial X5031370
Johan
Share this post
Link to post
Hi Loren! New to me 2001 996 turbo with Becker CDR220. PO didn't have the radio code and I'm about to disconnect the battery.
S/N: Y5043407
Thanks in advance!
Share this post
Link to post
S/N: Y5043407
Thanks in advance!
Try 0608
Share this post
Link to post
Request code for s/n: X5018630, please.
Model of radio please?
Whoops! Sorry, thought you only needed the serial.
Becker CDR 220
Type 4462
Share this post
Link to post
Becker CDR 220
Type 4462
The model number tells me how many digits (4 or 5).
Try 6034
Share this post
Link to post
Hi Loren, I've misplaced or lost my code card and hope you can help:
CDR - 220
TYPE: 4462
SERIAL# 15076358
Thanks in advance, I really appreciate what you do.
Doug
Share this post
Link to post
CDR - 220
TYPE: 4462
SERIAL# 15076358
Doug
Try 2981
Share this post
Link to post
I have a 2002 tt with navigation, do i have to pull the radio out to get the vin number? tried all the steps but I dont think they apply to my stereo.
I am new to the site, any advice will be greatly apreciated.
Share this post
Link to post
Please read the Lost Radio Code FAQhere
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Share this post
Link to post
Sorry, I should've read FAQ first!
It says "CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
:eek:
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
