pennyporsche
Hi, I hope someone can help. I just changed my battery of my new Boxster and I didn't know for the radio code. Any help would be appreciated.
Becker 1
type 4462
# Y5034951
Thanks a lot!
Try 2179
Share this post
Link to post
I know I've asked this before but my car got repainted and I lost the paper where I put the code :-(
Loren, can I get the radio code again, please :-)
SN# X5013597
type 4462
CDP2065
Share this post
Link to post
SN# X5013597
type 4462
CDP2065
Try 0121
Share this post
Link to post
MY 1997 993 cabriolet has a Becker.
model number BE 2182
serial number TE00357812 VOLT
Can any one help if so email me at steerpike5@aol.com
Thanks. G.
Share this post
Link to post
Thanks. G.
Try 9154
Share this post
Link to post
Lost my radio code and came across this great thread. Here's my info:
CDR-210
R 3297
V5016249
Can you please provide me with the code? Thanks in advance.
Share this post
Link to post
CDR-210
R 3297
V5016249
Try 4940
Share this post
Link to post
Hey guys,
Just got mine back from the shop and need to put the code in. I had two codes, one from the dealer and the one from the manual. I tried entering both codes (it shows 4 stars, as I punch in the codes, a star disappears with each digit, then when I'm done all 4 stars show up again and nothing has happened) but I think they either don't work or I'm entering it wrong maybe? Any help would be appreciated!
2002 C4S
Model: CR-220/CDR-220
Type: 4462
Serial: 15089051
24/99
Edited by bosstucker
Share this post
Link to post
Hey guys,
2002 C4S
Type: 4462
Serial: 15089051
24/99
Try 1723
Share this post
Link to post
Thanks Loren! Worked perfectly! I had 1728 as one of the codes so I think someone at the dealership has poor penmanship... Or I have terrible eyesight...
Share this post
Link to post
I have a 1997 boxter with a becker radio cdr 210.
pr-vers r 2896
sn v5008234
I bought it with the radio locked.
Can anyone help with a security code?
Share this post
Link to post
pr-vers r 2896
sn v5008234
Try 1360
Share this post
Link to post
pr-vers r 2896
sn v5008234
Try 1360
Thank you sooo much for the quick response.
I will try it when the wife gets back with the boxter.
Share this post
Link to post
Hi I'm trying to find code for after disconnecting my battery only to find the code I have listed in the ECU is incorrect.
The details are.
CR-22
Type 4367
Serial Y5021907
24/99
Many thanks.
Share this post
Link to post
The details are.
CR-22
Type 4367
Serial Y5021907
24/99
Many thanks.
Try 0893
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
