pennyporsche
Same problem. Disconnected battery for front end work.
Becker Automotive Systems
Type: CDR 21
Model: R1996
Serial: V5009351
Thanks - Seth
Share this post
Link to post
Type: CDR 21
Model: R1996
Serial: V5009351
Thanks - Seth
Try 9274
Share this post
Link to post
Type: CDR 21
Model: R1996
Serial: V5009351
Thanks - Seth
Try 9274
Thanks Loren
Share this post
Link to post
Loren I have a 2002 Boxer S no radio code in the book I put a new battery in abd the code comes up
CR-220
type ccr 220
model no. BE6624
serial # 15004294
12 volt ec 102
Share this post
Link to post
CR-220
type ccr 220
model no. BE6624
serial # 15004294
12 volt ec 102
Try 2849
Share this post
Link to post
Hi Loren
I need pls the code for my PCM 1 and Navi (Porsche 996, Bj. 2001)
Navigation Siemens, Serial No. : PO211011J0063
PCM1 Siemens A20, Serial No.: PO8030134023/03
and
PCM1 Cassette Becker IDIS
Modellnr. BE2580
Serial No.: Y5051229
Moses
Share this post
Link to post
Hi Loren
and
Modellnr. BE2580
Moses
Please read the Lost Radio code FAQhere
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Share this post
Link to post
Hi Loren
and
Modellnr. BE2580
Moses
Ohhh... Ok
Edited by Moses996
Share this post
Link to post
Hello Everyone,
I'm a longtime lurker of the forum, but a rare poster. I've got a bit of a problem. My radio code was lost and my battery died.
It's an aftermarket Traffic Pro.
MODEL: BE4763
SERIAL: 15000644
Here is a picture of the serial number, Porsche part number, and other relevant information on the unit. http://imgur.com/5983n
Thanks for your help!
Share this post
Link to post
Hello Everyone,
MODEL: BE4763
SERIAL: 15000644
Try 32225
Share this post
Link to post
Hello Everyone,
MODEL: BE4763
SERIAL: 15000644
Try 32225
Worked like a charm! Thanks Loren!
Share this post
Link to post
I have a CDR-220
Type 4462
SN 15064903
Thanks in advance.
Steve G
Try 7210
Thanks! 7210 works.
May the road rise to meet you,
May the wind be ever at your back.
May the sunshine warm upon your face,
and the rains fall soft upon your fields.
Share this post
Link to post
Wow. It's been years since I first wandered in here with my '98 Boxster and here I am again with a '99 911. I just couldn't stay away.
CDr-22
type 4462
serial w5011359
Thanks in advance for my code.
Share this post
Link to post
CDr-22
type 4462
serial w5011359
Try 0604
Share this post
Link to post
Hello guys, sorry for my bad english, I'm french..
So, I need for Radio Code from Boxster 986 2.7 220ch
Becker1
type 4467
serie X5021309
CDP2081
Can anyone help me please ?
Thank's a lot
Kiss
Share this post
Link to post
Becker1
type 4467
serie X5021309
CDP2081
Thank's a lot
Kiss
Try 7619
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
