pennyporsche
Had to reset my window w/battery disconnect...
Can't seem to find my paperwork.
If you please:
CR-220
type: 4362
ser: 15000053
Thanks in advance.
Try 0424
Share this post
Link to post
Hi I have -
Type - Cr22
Model no - BE4367
Serial no - X5017916
I've already had codes 3170 and 3159 and neither worked - can some one help?
Share this post
Link to post
Hi I have -
Type - Cr22
Model no - BE4367
Try 3160
Share this post
Link to post
Hi, my Carrera 4 2001 has same problem as referred to above as disconnected to change Control Box.
CDR-220
Becker 1
Type 4462
Ser # W5008233 (see photo I think as "33" LCD is not clear)
48/98
Please help. Look forward to your response.
Share this post
Link to post
CDR-220
Becker 1
Type 4462
48/98
Try 1352
Share this post
Link to post
Hi Loren, I have tried 1352, did not work then tried 1351, 1354 and still no good just waiting for reset code to try again. Any other suggestions much appreciated?
Share this post
Link to post
If that is your radio serial number ending in 8233 then the code I gave you (1352) should work.
Share this post
Link to post
Hi Loren, the original radio card states 233 without the 8, could we try based on this three digits. Thanks again.
Share this post
Link to post
No, my program requires the last 4 digits minimum.
You could remove the radio and see what is printed on the serial tag...
Share this post
Link to post
I just replaced the battery strap in my 993TT and now I need the radio code
CDR-220
BE 4337
Serial # 35045543
Share this post
Link to post
Hi Loren, I removed unit and found the 4 digit 1392 written on unit. Thanks again
Share this post
Link to post
Hi Loren, I have misplaced my radio code. Thank you in advance for your help.
CDR-220
BE4362
Serial# 15001846
Try 6820
Thank you soooooooo much it worked like a charm!!!
Share this post
Link to post
Hi I have -
Type - Cr22
Model no - BE4367
Try 3160
That worked a treat! Feel a bit daft not trying it now, just wen up in 2's instead ... doh!
Thanks, made my drive to lemans so much more enjoyable :D
Share this post
Link to post
CDR 22
1999 Boxster 986
4467
SERI X5012153
4998
if anyone can help me i'd really appreciate it
Try 5428
worked a treat Loren, thank you. nothing worse than driving without music
Share this post
Link to post
Cr-220
Type:44(5/6)2
Ser:x(5/6)02(9/8)1(h?)(5/6)
my radio is in a world of hurt. the parenthesis are because I am not sure which number it is. A strip at the bottom of the radio is dead so I cannot tell the difference between 5's and 6's, also 8's and 9's. If need be is there a more sure way to get the serial# without going through the system? Please and thank you
Share this post
Link to post
Cr-220
Type:44(5/6)2
Sorry, I can not do a lookup without a good serial number - so you will need to remove the radio and get the serial number off the tag.
Share this post
Link to post
CDR 220
4462
Y5045924
29/99
Thanks so much! The nearest dealer is several hours away.
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
