pennyporsche
We flowed the direction to get the radio code
We pushed in 4462
For our boxter 2000 with cdr 220 radio as this was hat it read
Code 4462
24/99
Serial code CDP2081
Can you help? So happy to have gotten our dream car but sad when we bought it a new battery and after inputting info I am not sure which button is seek signal, but code does not work ...no tunes is no fun.
Share this post
Link to post
We pushed in 4462
Code 4462
24/99
Serial code CDP2081
? I am confused - that is not a serial number that is the model code.
Please follow the procedure in the Lost Radio Code FAQ and re-post the correct serial number.
Share this post
Link to post
We pushed in 4462
Code 4462
24/99
Serial code CDP2081
... sorry serial number is Y5038020
Share this post
Link to post
We pushed in 4462
Code 4462
24/99
Serial code CDP2081
Try 2161
Share this post
Link to post
We pushed in 4462
Code 4462
24/99
Serial code CDP2081
the other question we have before attempting it is that some people haves said that you have to follow the code with a tap ofthe seek signal button, it thie the button marked "s" on the cdr220. we are urrently lockedout and hpe to geta screento try againbut was worried from other posts and replies that the code alone may have to be followed by the "seek service button". our buttons and radio do not have a manual so I want to make sure we can do what it wants .
we did buy the 101 things for your boxter book and have the full manual for schematics etc on order, but just want to try in the morning again when it gives me a chance. I will try 2161, and please tell me if I follow that by pushing the fifth item in the sequence as mentioned in very early reply to another confused porsche owner. ( my husband is happy with no music because he likes to hear the throaty throttle sound, but me, I love tunes while driving and sure hope we didn't mess up this option by not knowing the sequence once the four digit codes are input. Thank You so much for your help if it works, and for your time if it isnt able to. So glad this forum exists! thank you inadvance. Thebutton i assume it is says"S' on the cdr 220.so happy that you are able to help others, sure wishI hadany guru possibilityies inmy life, look howmuchyouare doing for happy porsche owner!!!
so I will enter the four digits you gave me and do or do not I push the "s" button on the stereo fascia. ? I cant find info on the meanings button on the cdr 220 anywhere...you my be my only hopeand we'd love to donate a little for you cause.... ( and our solve hopefuly!)
Try 2161
Share this post
Link to post
Please, my boxster battery went OFF and after that my CDR-22 stereo need code. I'd appreciate some help. here is the radio data:
Becker 1
Type: 4467
CDP2081
Serial: Y5024785
24/99
Share this post
Link to post
Becker 1
Type: 4467
CDP2081
Serial: Y5024785
24/99
Try 9097
Share this post
Link to post
Becker 1
Type: 4467
CDP2081
Serial: Y5024785
24/99
Try 9097
Works geat!
Thank you
Share this post
Link to post
Restoring my 996.2 GT3 back to [as close to] OEM Spec [as possible!] and have sourced a CDR23 to replace the Pioneer SatNav Monster that the previous owner installed.. Any help/info on the Code greatly appreciated..
CDR23
EC: 126
Model No.: BE 6612
Serial No.:45073209
Accession No.: 0331621
Date of Manufacture: 13/04
Many thanks.. :help:
Share this post
Link to post
CDR23
EC: 126
Model No.: BE 6612
Serial No.:45073209
Please read the Lost Radio Code FAQ
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car?s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Share this post
Link to post
CDR23
EC: 126
Model No.: BE 6612
Serial No.:45073209
"CDR-23 (or later):
Aha :blush: Thank you :thumbup:
Share this post
Link to post
Hello, glad I found this forum. By any chance do you have the stereo code for the following:
Car: 97 Porsche 993
Stereo: CDR-210
Model: R 2896
Ser No. V5005552
Share this post
Link to post
Car: 97 Porsche 993
Stereo: CDR-210
Model: R 2896
Ser No. V5005552
Try 5476
Share this post
Link to post
good morning just bought an 02 boxster and need the radio codes.. cdr220 ser#15005612 any help with the unlocking code would be appreciated
then on to the top and brake light problems!
thank you great site
Share this post
Link to post
Try 9540
Share this post
Link to post
Hello,
I heard about this site from 6 Speed...Hopefully it works for me! I just bought the car from an independent dealer...They replaced the battery while I was there. The NAV / Radio worked prior to them changing it out. Then it required the codes (NAV & PCM) which we did not have. Now it locks us out for 60 minutes.
Anyway, here is the info that I think you need.
Car: 2001 996 TT with NAV
VIN: WP0AB29941S685363
Model: BE2582
Serial #: 25010605
THANKS IN ADVANCE!!
Share this post
Link to post
Hello,
Model: BE2582
Serial #: 25010605
THANKS IN ADVANCE!!
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM?s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
Share this post
Link to post
Hi Loren,
New owner of an 02 Boxster planning a Window Regulator change and will need my code which is GOA.
CDR 220
Type 4462
SER 25013340
Thanks in advance for your help!
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
