pennyporsche
Yet another car missing the radio code. I am going to unhook the battery to install the original steering wheel/airbag and do not have the radio code. Also, I would like to know if there is a way to verify that the code is correct without having the radio locked. Radio is:
Becker 1
type: 4462
Serial number: 15005578
Boxster S 2002
Share this post
Link to post
I hope someone can help with my code. I replaced my battery and now the radio is asking for a code. Here's my info:
CDR-220
BECKER 1
TYPE 4462
SER: Y5036852
24/99
Thanks very much in advance. :D
Try 2835
or 2837
Thanks for the quick response but neither number worked. Am I doing something wrong or are there other numbers I can try?
Thanks so much for the help. :)
My program does not always work. It works maybe 95% of the time but I have no expanation why it doesn't always work.
At this point you will need to contact a dealer or Becker. Becker charges to lookup your code and some dealers do too.
Loren, 2838 worked. Thanks for leading me in the right direction. You saved me a trip to dealer and $$. Thanks again.
Share this post
Link to post
Help. I need a radio code for a CDR-210 in a 1999 996 I just bought. It is showing CODE with the "C" flashing.
I think the S/N is W5018297
And what is the procedure to enter it? I see the buttons below correspond to the digits I enter, but is there a button I press/hold afterwards to confirm entry? My car does not have an owners manual (I plan to buy one).
Thanks for any help.
Share this post
Link to post
Here is the link to download the manual for the CDR-210: http://www.renntech.org/forums/index.php?a...mp;showfile=543
I can't give you a code, but hopefully Loren will see your message and help you out.
Good Luck!
Share this post
Link to post
Try 5446
or
5448
Share this post
Link to post
Try 5446
or
5448
Share this post
Link to post
Try 5446
or
5448
Neither code worked. I entered the code and then pressed the signal seek switch each time.
I got the S/N br pressing the 8 and 0 at the same time and selecting S/N - is that the best way or should I pull the unit and look at it? Thanks.
Share this post
Link to post
Sometime the program does not work and in that case you will need to contact a dealer or Becker.
I do not know about a CDR-210 but on CDR-220 you don't press any keys after the code.
Share this post
Link to post
Thanks for the try. I do appreciate it!
Share this post
Link to post
You guys have been great helping out others with their lost radio codes. Think you might be able to do one more?
2001 Boxster S
Becker 22o
serial Y5023592
Type 4362
Please?
Share this post
Link to post
Hi, I hope someone can help. I just had my car painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4462
# Y5038582
24/99
Hi Penny.
How did you get the information about type and number that you posted? I have no paper work on my CR-210. Also, when you entered the codes that were suggested to you, what procedure did you use? Just replace CODE with the four digit number? And then the first number kept blinking. What did you do?
Thanks for passing along the information you already got.
Nancy
Share this post
Link to post
Hi i bought my car from auction and it has no radio code :(
BE 6625
Serial # 15005923
Thanks so much its killing me not having any tunes!
Share this post
Link to post
BE 6625
Serial # 15005923
Try 7177
or
7179
Share this post
Link to post
Same issue. 2002 Boxster. Replaced battery and do not have radio code. Any help would be appreciated
Terry
Becker 4462
serial number Y5035192.
Share this post
Link to post
Hi loren
I had a misfire fault code on no 5, so replaced all the coils as some had cracks in . done a reset on the DME as per some article on another website to clear the CEL more than 20 sec but less than 50 and you wont lose the radio code, well guess what, i lost the radio code any chance of some of your magic please
It has a cdr-22 radio. my vin is ys604059 model no 986 311 anything else you need to find it out
many thanks in advance
Russ
UK
Share this post
Link to post
Hi loren
Russ
UK
Is that your VIN or radio serial number?
If it is your radio serial number then try 8893
or
8895
Share this post
Link to post
Hi loren
Russ
UK
or
8895
Hi Loren
Many thanks for your prompt response. Thats my vin number ys604059 where would i find the serial number for the radio
Russ
Share this post
Link to post
How to get your radio to display the serial number has been covered here many times. As well you can download the manual here.
Please do a search...
Share this post
Link to post
Learn something new everyday switch on hold down TP for 10 seconds. would'nt have found it without this forum many thanks.Could'nt find how to do it in the radio manual that came with the car.
Becker 1
type 4467
Serial no Y5026921
24/99
Share this post
Link to post
Becker 1
type 4467
Serial no Y5026921
24/99
Try 6971
or
6973
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
