pennyporsche
I think you might have missed me, since you already replied to a person more recently. So, I'll post again...
I also need the access code.
Model 4462
Serial number: 15075918
Ed
Sorry.
Try 7140
Share this post
Link to post
Model 4462
Ed
Sorry.
Try 7140
It worked!! Thanks so much!!!
Share this post
Link to post
Hope you can help with a UK supplied car?
CDR 22,
Becker 1,
type 4467,
serial Y5022954.
Many thanks.
Kind regards,
Steve
Share this post
Link to post
CDR 22,
Becker 1,
type 4467,
serial Y5022954.
Many thanks.
Kind regards,
Steve
Try 4763
Share this post
Link to post
Hi Loren
From Spain... Hope you can help me..
Becker traffic pro
BE4760
X5005086
Many thanks for your help
George
Share this post
Link to post
Hi Loren
Greg from Wisconsin.
2000 boxster
Becker CDR220
4462
x5037347
Thank you so much for your help.
Share this post
Link to post
Hi Everyone, my name is Marcelo, I hope can help me with my radio code, here the details:
Boxster 2001
CDR 220
Model BE 4462
Serial Y5051175
Thank you very much!
Share this post
Link to post
Boxster 2001
CDR 220
Model BE 4462
Serial Y5051175
Try 8378
Share this post
Link to post
Can you please help with the Code for my 2002 Boxster S, CDR 220, model 4462, Ser# X5017062
Thanks very much!
Edited by 02BoxsterS
Share this post
Link to post
HI I am about to fit an Aux cable to my CDR-32 radio but have not got the card for the code can anyone help?
Type: 4667
Serial : Y5022400
Many Thanks
Dom
Share this post
Link to post
Type: 4667
Serial : Y5022400
Many Thanks
Dom
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car?s DME and can only be replaced by a shop with a PST2 orPIWIS. These radios will not request a code when battery power is disconnected."
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
