pennyporsche
Lost my code by replacing battery. I have the serial number it is v5005463. Please help
I do not understand why you posted 3 times and sent me two Personal Messages.
Apparently you did not read the part of the Lost Radio Code FAQ that says "Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread."
Try 2180
Share this post
Link to post
You have to hit the tuning button on the CR210 in order to "Input" the code.
If you do that and the code 2180 still does not work then your radio is one in 10,000 - that does work with the code. Sorry.
You will need to contact a Porsche dealer or Becker North America.
Share this post
Link to post
Hi I got a new battery,and you probably know what i need help with radio code i have is 9612 but it doesnt work,can anybody please help. Becker cdr 220
It is type 4465
Serial # 15075065
Share this post
Link to post
It is type 4465
Serial # 15075065
Try 9259
Share this post
Link to post
Hi, please i need code for radio
Porsche Cayenne
Model no: BE6635
Serial no: 45042977
VERY VERY THX
Please read the Lost Radio Code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Share this post
Link to post
I was toying with my stereo (thinknig of changing it) and removed the rear plugs without thinking. Now its asking for a code.  :oops:
It is a Becker CDR22. Model no. BE 4467 Serial no. 15038590
Many thanks
:blush:
Share this post
Link to post
Many thanks
:blush:
Try 5714
Share this post
Link to post
Oh great and powerful Loren ...
CDR-210
R 3297
W5024890  (maybe the "5" is an "S"?)
LV
Try 7106
Nailed it in 1.  This garage be a rockin!   Thanks Loren!
LV
Share this post
Link to post
Kind sir,
after a battery replacement, I need your help!
2001 996  Carrera 2
CDR 220
Model # 4462
Serial # Y5054325
Marvin
Share this post
Link to post
Kind sir,
2001 996  Carrera 2
CDR 220
Model # 4462
Serial # Y5054325
Marvin
Try 3097
Share this post
Link to post
I just got a 02 996TT via a Chevy Dealer in a tiny town in Minnesota. I guess they wanted  to keep the car "safe" so they disconnected the battery and nobody has the code card or notes.
Becker CR 220
Model 4362
Ser # 15003427
Thank you, Loren!
Edited by techweenie
Share this post
Link to post
Kind sir,
2001 996  Carrera 2
CDR 220
Model # 4462
Serial # Y5054325
Marvin
Try 3097
Many thanks, worked like a charm.
Share this post
Link to post
I'm new to Renntech so I hope I'm in the right place to ask question about radio.  I recently purchased a 1998 Porsche Boxter with an after market radio however the original radio was with the car but no radio code,  Radio #CDR210, Model #EE2262, Serial # W5019267.  Any help would be appreciated,  Also if anyone knows how to bench test the radio to make sure it works.  Many thanks, Jim
Share this post
Link to post
Try 1434
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
