pennyporsche
Thanks Loren. I was meaning to try it over the weekend and let you know if it has worked or not, but didn't get a chance. Will prob next have a moment next weekend. Thanks in advance.
Share this post
Link to post
Hello,
I had my car worked at a shop and they disconnected the battery and now my stereo doesn't work.  My stereo is a Becker?Siemen's Navigation System.  Any help with the code or codes, please?  Any help would be highly appreciated.  Thanks...
It's a Becker 2582
Serial Number #15008512
Siemen's Serial # PO8040065836/03
Share this post
Link to post
Hello,
It's a Becker 2582
Please read the Lost Radio Code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Share this post
Link to post
Dear Loren
I hope the below works out, as i suppose it wont.
Thank you in advance
All the best
Share this post
Link to post
Thank you so much Loren for doing this.
My dad is going nuts trying to fix it.
Becker 1 Model 4462
Serial # 25015104
Try 9571
It worked! Thanks again!
Share this post
Link to post
Hi
I have a Becker BE6612 35046372
"How to get your radio serial number?
CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Share this post
Link to post
99 Boxster was fitted with IMS Solution - battery disconnect lost radio.
Becker CDR-220
Type: 4462
Serial:Y5045475
thanks in advance!
Share this post
Link to post
Hi.  Thank you so much in advance for any help.
2000 Boxster - 3rd owner, no code, battery disconnected
Becker CDR220
Type 4462
Ser Y5040927
Thanks again!
Share this post
Link to post
Becker CDR220
Type 4462
Ser Y5040927
Thanks again!
Try 4827
Share this post
Link to post
Loren, thank you for your reply regarding my radio code, however 1434 didn't work??  The information on my radio as follows:  Becker# CDR210, Model#EE2382, Serial # W5019267 ( the "9" may not be correct as it looks like a "9" without the bottom part of the number??  Any help would be greatly appreciated.   Many thanks, Jim
Loren, Went thru the steps for lost radio code and serial number came back as W5019267, however the model came back as 3297? None the less I went back out and tried the code again. After entering the code the number "1" was flashing, I pressed the arrow up button and it immediately went to a radio station. So all is good except now the CD player isn't working. Any idea's. Thanks so much for your help I wasn't aware of the Lost Radio Code page. Many thanks, Jim
Edited by Loren
Sent as an error report....
Share this post
Link to post
Did you use the procedure in the Lost Radio Code FAQ to get your serial number?
If you did not, then please do and report back here.
If you did and this code does not work then I am sorry - someone has changed something inside that radio.
Share this post
Link to post
Becker CDR220
Type 4462
Ser Y5040927
Thanks again!
Try 4827
It worked.  Thank you so much.
Share this post
Link to post
Loren, I replied to the above post but don't know if I was in the right place?  Really new to Renntech.  Anyway, I did go to the Lost Radio Code sight and went thru thr steps.  The radio code came back the same W5019267 howevcer, the model # came back as 3297??  Anyway I tried setting the code again and noticed mthat after entering the code the "1`" was flashing so I pressed the right arrow up key and it turned on and went to a radio station.  So all is well except now the CD player dosen't work now??  Thanks for all the help really appreciated, Jim
Share this post
Link to post
Hey Loren
I need your help.
Need the code for CDR 22
BECKER 1
TYPE 4467
Serial X5009923
45/98
Much appreciated
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
