pennyporsche
Hi Loren,
I appreciate you having this thread! Just picked up my first 97 Boxster today. Unfortunately don't have a code :(
Becker CR-210
R 2896 V5009070
Thanks in advance!
Share this post
Link to post
Hi Loren,
Becker CR-210
R 2896 V5009070
Thanks in advance!
Try 1875
Share this post
Link to post
just purchased 2002 boxster s and need code.  radio is Becker CDR-220 with serial #:
15005259
many thanks!!!!
Share this post
Link to post
Thanks so much mate!!!!!
Merry Christmas.
Hi there,
I lost my code for my cdr22 hope you can help.
Ser: X 501 6755
Much appreciated.
Try 4893
Share this post
Link to post
15005259
many thanks!!!!
Try 8794
worked like a charm!  you guys are great!
Share this post
Link to post
I have a 2001 911 Carrera and just replaced the battery.  I do not have the Radio Code Card (looks like I did not get it when I bought  the car new).  My radio type is 4462 CDR-220.  The serial # is Y5048840.  Any help is appreciated.
Thanks.
Share this post
Link to post
Thanks.
Try 9281
Share this post
Link to post
Hoping you can help.
I have lost the code to the following radio
Becker CDR 220
type BE 4462
serial # Y5037957
Share this post
Link to post
Hello,
A radio code is need, please, regarding my Becker 1 radio 4462 that bears serial number 15063093 in 1 2001 Boxster.
Try 0174
Share this post
Link to post
Becker CDR 220
type BE 4462
serial # Y5037957
Try 7072
You are a legend. Thanks.
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
