pennyporsche
Can I get a code for a Becker please?
Serial no. V5003067.
Thanks in advance.....
Ash.
Hi.
it's CR-21
Ash.
Share this post
Link to post
Ash.
Hi.
it's CR-21
Ash.
Try 9151
Share this post
Link to post
Hello got my 2000 Boxster S back on the road after a near 4 years rebuild. Code for my Becker CDR22 Type 4467 Seri X50 12458 would be much appreciated. Thanks.
Share this post
Link to post
Ash.
Hi.
it's CR-21
Ash.
Try 9151
Thanks for code, works fine.
Share this post
Link to post
Hello! Locked out on my 2000 boxster s
CR-2200
Type: BE 4466
Seri: Y5012375
47/98
Thanks in advance!
Edited by carterh232
Share this post
Link to post
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Strange thing though, I have the radio code card and the serial number matches the one shown on the radio display. I even called the Porsche dealer, same numbers, but the code doesn't work....there used to be that Java applet for this and when using that I remember using a different code. What do you come up with? Thank you so much!
Share this post
Link to post
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Try 4395
Share this post
Link to post
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Try 4395
Yep that's the one I have, and it didn't work. It just goes back to the first digit and keeps blinking.
I seem to remember the code that worked had something like 536X? Are there any other options?
Share this post
Link to post
1998 Boxster
CDR-210
Type: R3297?
Serial: W5021637
Try 4395
The only code for that serial number is 4395. So if that does not work and you are sure the serial is correct then you need to contact Becker North America.
Share this post
Link to post
Hello, I've lost the code to my 2000 Boxster S
CDR - 220
SERIAL NUMBER: Y5039049
Thank you for the help in advance
-Cheers Rob
Try 1707
Share this post
Link to post
Good day
Need a code for a Becker CDR-220 in 1999 996
Type 4462
Serial Y5051974
Much obliged!
Share this post
Link to post
Thanks for such a quick reply. I'm installing the rear speaker kit this weekend and will need the code then. I'll reply again and let you know if 6403 worked. Thanks again for the help ... Love reading this forum
Thanks again, the code worked and I'm now enjoying the back speaker addition :)
Share this post
Link to post
Need help with the following
CDr-220 serial number x5038006
Thank you
Share this post
Link to post
Thank you
This is the 3rd radio code you have requested a code for in the last two months - perhaps you should consider a donation to this site.
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
