pennyporsche
Just got my 996 back yesterday after an engine replacement.  Unfortunatly they disconnected the battery and now no more tunes.  The engine is nice to listen to finally so not that upset. :-)
Model: BE4362
Serial: W5010328
Many thanks!
Try 0546
Worked perfectly Thank you so much!
Share this post
Link to post
Hi, just bought a 996 c2 and can't find codes. Asked previous owner and they don't know either. Type: 4367. Serial: x5014127 would be very much appreciated if you could help. Cheers
Try 0760
Share this post
Link to post
Try 0760
Many thanks, all working!
Share this post
Link to post
Hi, could you help me to find my radio code
Model: CD-R 220
Type: 4362
SN: 25005359
Try 3179
Model: CD-R 220
Type: 4362
SN: 25005359
Try 3179
Worke perfectly. That's awesome.
Thank you so much.
Share this post
Link to post
Hello
disconnected battery to replace AOS on my 911 now radio will not work PLEASE help with security code #
my Becker cdr 220 s/n is 15064383
member
Texas Bob
airbearing@hotmail.com
Share this post
Link to post
Hello
member
Texas Bob
Try 7145
Share this post
Link to post
Thanks in advance to you, Loren. My alternator died and now I need the code for my CDR 220
Model -- BE 6625
Serial -- 25015580
Thank you for doing this!
Try 9284
Oh man that was it.
Thanks so very much.
Share this post
Link to post
Hi Loren;
Can you help me with the radio code for my '00 Boxster.
Becker 1
Model: CDR-32
Type: 4667
SN: X5020085
Best regards.
Share this post
Link to post
Hi Loren;
Becker 1
Model: CDR-32
Type: 4667
SN: X5020085
Best regards.
Please READ the Lost Radio code FAQ
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Share this post
Link to post
Hi Loren;
Becker 1
Model: CDR-32
Type: 4667
SN: X5020085
Best regards.
"CDR-23 (or later):
Dear Loren;
Please check the photo I have taken 5 mins ago below;
Anyway, I found a little code calculator tool which has given me code 4264, went down in the lot and bam radio working again.....
Share this post
Link to post
Hi Loren,
I have a Becker 1 and the Serial number is Y5050752.
Ed
Try 2674
That was it, thank you very much,
Ed
Share this post
Link to post
Hello -
Thanks for offering up this service, I can use some help..
I have a Becker CDR-210
BE2282
Serial # V5005501
Porsche part # 993.645.120.01
Thank you very much!
Regards,
Al
Share this post
Link to post
Hello -
BE2282
Serial # V5005501
Regards,
Al
Try 1484
Share this post
Link to post
Hello, I have a used Porsche 911 Carrera which just had a new alternator installed and, as a result, I too need the authorization code for the radio/CD player. The radio's specs are as follows -
Radio: Becker1
Type: 4462
Serial: X5023280 -> 48/98
Any help would be greatly appreciated!
Larry Fry
Houston, TX
Share this post
Link to post
Radio: Becker1
Type: 4462
Larry Fry
Houston, TX
Try 2423
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
