pennyporsche
 I need to get my radio becker CR-220 type 4462 serial Y5045347, I recently did a rebuild and lost the code, please help!!
Third time you have asked.
I answered your first request here
Share this post
Link to post
I do not have my radio code and I need to disconnect the battery as I will be working with the horn and I do not want the airbag to deploy. What information is needed to get the radio code? Thanks in advance. My car is Boxster 2000.
Share this post
Link to post
Please read and follow the procedure in the Lost Radio Code FAQ.
Share this post
Link to post
Posted Yesterday, 08:30 PM
benedick, on 07 Oct 2015 - 7:59 PM, said:snapback.png
Got it, I will follow it and contact you, thanks again.
Edited by benedick
Share this post
Link to post
Radio is CDR-220
Type 4462
Y5040741 or YS040741
24/99
GAL 00
Share this post
Link to post
Radio is CDR-220
Type 4462
24/99
GAL 00
Try 2586
Share this post
Link to post
Hi Loren,
Thanks for providing this valuable service to Porsche owners everywhere! My code has also been lost. Details are:
Model: Becker 1
Type: 4462
Ser #: Y5045599
Much appreciated.
Try 9436
Thanks so much!
Share this post
Link to post
Hi Looking for a code for a CR-220
Model BE 4362 - Serial 15031342
Martin -Mcamphr
Share this post
Link to post
Hi - I need to recover my radio code for the following after battery change:
CDR-220
Serial # Y5044828
Thanks in advance for your kind assistance.
James
Share this post
Link to post
CDR-220
Serial # Y5044828
James
Try 3026
Share this post
Link to post
Hello,
I have just changed battery on my 2001 Porsche in Sweden with the Becker CDR-22 Radio but I have lost my radio code card.
Radio Model nr. 4467
Serial nr. 25007321
I would be very thankful for any help!
/Helle
Share this post
Link to post
Hello,
Serial nr. 25007321
/Helle
Try 8910
Share this post
Link to post
It worked! Thank you very much for your help Loren, very kind of you to take the time and find the right code!
Saved me a lot of time and money contacting my dealer etc.
Kind regards
Helle
Share this post
Link to post
Hello, I lost the radio codes for my 99 Boxster:
CDR 220
Type 4462
S/N   X5026003
thank you for any assistance you can provide
Share this post
Link to post
CDR 220
Type 4462
S/N   X5026003
Try 1405
Share this post
Link to post
Can anyone help me retrieve my radio code for my 2002 Boxster. I misplaced the code. Radio is a Becker1CDR 220,  type4462, serial # Y5041389, 24/99
Share this post
Link to post
Try 0854
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
