pennyporsche
I have a 98 Porsche boxster asking for a code it's a cr-210
Becker 41996
Vr5006281
And I can't get the code to work
Share this post
Link to post
HI there Loren, I hoping you can help me find my radio code
I have a Porsche Boxster 986 1997
Serial N. VS600894
CR-210
by the way the screen says "WAIT", I guess it is because I tried too many times and failed.
Try 0979
Oh sorry I did another comment, just to let you know that it didn't worked, the 0979 code
Did you follow the procedure to get your serial number in the Lost Radio Code FAQ?
Please do so and re-submit.
Serial N. VS600894
CR-210
Try 0979
Hi Loren the
SN: T5002155
I will thank you a lot for you help for the code
Thank you
So just to make sure you have the info the instructions require :
It is a Porsche Boxster 986, 1997
Becker
PR-VERS: R 1996
SERIAL N.: T5002155
Thank you very much, and sorry for the amount of comments!
Share this post
Link to post
Serial N. VS600894
CR-210
Try 0979
Serial N. VS600894
CR-210
Try 0979
Hi Loren the
SN: T5002155
Thank you
Becker
PR-VERS: R 1996
SERIAL N.: T5002155
Try 5454
Share this post
Link to post
Hi Loren
Hope you could help me on this one.
2001 911 Carrera
CR-2200
Type: 4466
Serial: X5011757
Your help will be greatly appreciated. Thanks
Try 2524
Share this post
Link to post
Hi Loren
2001 911 Carrera
CR-2200
Type: 4466
Serial: X5011757
Try 2524
It worked! Thank you!
Share this post
Link to post
Hello friends,
I am new on Porsche and I am having issues to unlock my radio.
CR-220
Type: 4362
Serial: Y50244700
The problem also is as soon as I turn it on, the WAIT message is displayed and it is not asking for the code.
What do I do?
Gerson Garcia
Share this post
Link to post
Hello friends,
CR-220
Type: 4362
Serial: Y50244700
What do I do?
Gerson Garcia
Start by reading the Lost Radio Code FAQ
Try 4843
Share this post
Link to post
Yes Loren I tried:
I get a WAIT in the display - what do I do?
You have to wait at least 30 minutes before trying again.
But do I need to wait 30 min with the radio ON?
Thank you again,
Gerson
Share this post
Link to post
Yes Loren I tried:
Thank you again,
Gerson
It does not matter - it is an internal timer.
Share this post
Link to post
Hello,
I changed batteries and don't have the radio code.
Have a 2002 Boxster
CDR 220
type 4362
Serial # 1500 3673  24/99
Can you help me?
Art
Share this post
Link to post
Hello,
Have a 2002 Boxster
CDR 220
type 4362
Can you help me?
Art
Try 4303
Share this post
Link to post
Hello,
Have a 2002 Boxster
CDR 220
type 4362
Can you help me?
Art
Share this post
Link to post
Hello,
Have a 2002 Boxster
CDR 220
type 4362
Can you help me?
Art
Try 4303
Thank you.  It worked.  How do I donate?
Art
Share this post
Link to post
Hello,
Have a 2002 Boxster
CDR 220
type 4362
Can you help me?
Art
Try 4303
Art
Thank you!
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
