pennyporsche
Hi Loren,
I'm looking for the code for my 98 Boxster.  My radio is a Becker CR 210.  The model number is R 3297, and the Serial Number is v5007532.  Thank you!
Share this post
Link to post
Hi Loren,
Try 1352
Share this post
Link to post
I have a 2000 911 need radio code, This would be much appreciated. THANK YOU!
type 4362
SN 15000736
24/99
Try 2546
thank you 911 times!! worked perfectly
Share this post
Link to post
I have a Porsche 996 with Becker Radio
I lost The CODE . Can you help me ?
CDC-3 11081196 is on the Radio Card
It ist a   BE2580
But on the Radio ist the Serial Number  :  15085965
Please help me
Share this post
Link to post
It ist a   BE2580
Please help me
You posted this three times but never read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Share this post
Link to post
Thx. Loren. I tried that and it just go back to the first number with 4387. Is there something else I'm supposed to press?
It worked Loren after pressing the the up volume button. Thank you!
Share this post
Link to post
I recently replaced the battery in my 2002 C4S and the radio code that a previous owner wrote in the manual is incorrect. I have tried the codes the dealership gave me without success. Can someone give me some advice please. The radio is a CRD 220, Serial number is 25014014.
Thanks very much. I hope I can help with something I know about in the future.
MDB
Share this post
Link to post
MDB
Try 4953
Share this post
Link to post
Will do, after another hour....
Thanks very much.
Share this post
Link to post
GIN!
Thanks very much Loren.
I paid radio-code.com for a code that did not work and have did not heard a word from them after two weeks and four emails. We will see if they guarantee my satisfaction or not like they promise with a refund of my money for not delivering.  Very frustrating.
MDB
Share this post
Link to post
Thanks in advance Loren.  Becker 1,  Type 4362,  Serial # X50 150 79       1999 Porsche 996 Cab
  Ron Schanfish
Try 9371
Thanks,  Worked like a champ!  Ron
Share this post
Link to post
Hey I'm trying to find the radio code for my Boxster could someone please help me? The model number is BE2282 and the serial number W5023160. It's a 1999 Boxster. Thank you for the help
Share this post
Link to post
You obviously did not read the Lost Radio Code FAQ...
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
