pennyporsche
I need help for my lost PIN code after battery change.
911 996 from 2003
Serial 35013134
Type 6632
Thanks!!
You obviously did not read the Lost Radio Code FAQ first...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Yes, I read too late. My Apologies!
Share this post
Link to post
Hi Loren, I do not have my radio code for my radio, it is a Becker  Type CDR 220, S/N X5024921, Model # BE 4462, hopefully you can help me.
Thank you.
Share this post
Link to post
Hi, I hope someone can help. I just had my 2001 boxster painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated. I checked under the hood and my manual book. None is writen. Below is the radio info
Becker1
CR 220
TYPE 4362
24/99
SERIES: Y5024520
Share this post
Link to post
Hello I am need of my radio code for my 2000 boxster s. Becker radio 220 model 4462 serial y5039027.
thank you
Albert
Share this post
Link to post
Thank you.
Try 7354
Share this post
Link to post
Becker1
CR 220
TYPE 4362
24/99
SERIES: Y5024520
I have removed your duplicate posts - please post ONLY one time.
Try 5410
Share this post
Link to post
Hi Loren I've been looking everywhere for help and I'm so glad I've found your thread. I have a 2001 boxster base
Becker 1
Cdr-220
Type 4462
24/99
Serial:15088602
Share this post
Link to post
Becker 1
Cdr-220
Type 4462
24/99
Serial:15088602
Try 5810
Share this post
Link to post
99 c2 cab
4462
X5012930
Any ideas Loren?
Try 0987
That was it. I will right it down, but I will be disappointed with myself if I forget it. 0987 is almost as obvious and easy to remember as 1234. Thanks Loren
Share this post
Link to post
Hi, my battery died and i can not find my radio code.  2001 C2, CR-220 4362 Y5030347.
Thanks for your help
Try 0698
Thanks, that worked
Share this post
Link to post
Looking for a radio code cr220 y5048721  Do i just enter the code or do i have to push something after code.
Share this post
Link to post
thank you
Albert
Share this post
Link to post
thank you
Albert
Try 1531
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
