pennyporsche
Me too... Changed the battery and lost the code...
Becker 1
CDR-22
SER: Y5023264
regards,
Nils.
Share this post
Link to post
Hi I need the radio code for my CDR-220. Serial number is X5031823. Thanks for your help!
Try 7636
Thanks, that worked!
Share this post
Link to post
Need help with code!!
CDR-220
Type: 4462
S/N: Y5041202
Try 8594
Thanks so much Loren!! it works
Share this post
Link to post
Becker 1
CDR-22
SER: Y5023264
regards,
Nils.
Try 3295
Thanks a lot. Worked perfectly! Thanks again :-)
Share this post
Link to post
Hi : I lost my Radio Code. I followed yor instructions and found the following: Becker 1, Type 4462, serial # 250 15235.
Thank you in advance for your assistance with this request.
Keep on
Share this post
Link to post
Keep on
Try 5018
Share this post
Link to post
Hello I lurk on this site but now I need some help!!! My father's car battery died while in storage...and now he can't get his radio working.
Radio is CDR-220
Becker 1
Serial X5020541
Share this post
Link to post
Radio is CDR-220
Becker 1
Serial X5020541
Try 0243
Share this post
Link to post
First thanks for helping everyone out...this is the way society is supposed to work. New owner 2000 booster cdr-220 type 4462 serial number Y5043714
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
