pennyporsche
First thanks for helping everyone out...this is the way society is supposed to work. New owner 2000 booster cdr-220 type 4462 serial number Y5043714
Try 8215
Share this post
Link to post
I had to find a replacement radio :(
Replacement one I got: Becker CCR220 , serial No 15000130
Thank you again.
Try 8208
Share this post
Link to post
I am new to the forum. I recently replaced the battery on my vehicle and had no clue about the code requirement. Can you assist?
Becker 1 CDR220 Ser: Y5045915
Thank you!
Share this post
Link to post
Thank you!
Try 7216
Share this post
Link to post
Loren,
Thank you so much, it worked perfectly. I just wrote it down under the hood and about 3 other places for future reference.
Share this post
Link to post
HI Loren,
Hoping you can help me out with this.
Its a PCM1 unit
Type: IDIS
Model: 2582
Serial:  15008655
Thank so much.
Share this post
Link to post
HI Loren,
Its a PCM1 unit
Type: IDIS
Model: 2582
Serial:  15008655
Thank so much.
Youd did not read the Lost Radio Code FAQ... did you?
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Share this post
Link to post
Hi Loren,
Can you help me out with cdr220 radio code
mode no: BE6625
serial no: 25014462
Hope to hear from you soon.
Share this post
Link to post
Hi Loren,
mode no: BE6625
serial no: 25014462
Try 1362
Share this post
Link to post
Hope you're having a nice long weekend. You do a great service in getting codes for people. I'm sure you've heard it a million times what a silly design Porsche created with these radios.
Anyway now I finally have to ask for help! Like asking for directions back in the days before smartphones and navigation systems!
i have a 2000 Boxster and need the code after  a battery change.
CDR 220
4462
ser Y5040456
Share this post
Link to post
CDR 220
4462
ser Y5040456
Try 8738
Share this post
Link to post
Thank you in advance if you can help.
i have a 1999 Boxster and need the code after  a battery change.
CDR 220
4462
ser W5011597
My best,
Emilio
Share this post
Link to post
CDR 220
4462
ser W5011597
My best,
Emilio
Try 0491
Share this post
Link to post
CDR 220
4462
ser W5011597
My best,
Emilio
Try 0491
Thank you very much. Worked like a charm. Have a great weekend and really appreciate the help. Cheers.
Share this post
Link to post
Lauren,
I do not know how you and your team handle so many requests, but thank you!
For me, it is type 4462
Serial number X5024968
(48/98)
Terry
Share this post
Link to post
Lauren,
(48/98)
Terry
Try 1315
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
