pennyporsche
HI loren,
I appreciate any help on obtaining a lost radio code
2002 Boxster
Becker  4462
serial:  25012097
THank you so much
Share this post
Link to post
HI loren,
2002 Boxster
Becker  4462
serial:  25012097
THank you so much
Try  0396
Share this post
Link to post
New to Porsche. Disconnected battery when I put my boxster away for winter. Should'very got a battery tender. Learning fast!...so now need a radio code...
2002 Boxster S
Becker CDR-220
Type 4462
Serial# 25010619
Thank you...
Share this post
Link to post
2002 Boxster S
Becker CDR-220
Type 4462
Serial# 25010619
Thank you...
Try 4541
Share this post
Link to post
I have a 99 Carrera, Becker CDR220, Type 4462 Serial X5016024.
I appreciate any help you can give with unlock code.
Try 5157
Share this post
Link to post
Got a used radio for a 2001 Boxster S.  CDR-220, BE-4462, SN#: 15087102
How do I get a code for a used radio that has no code?
Also, this Boxster has a mic and jack in the empty hole.  Was there a CDR-220 that came with cell phone usage and a mic jack on the back.  This used one does not have a place for it.
Jay
Edited by PlanoPorsche
Share this post
Link to post
Jay
Try 6591
Please post other radio question in a separate thread - this thread is for Lost Radio Codes Only.
Share this post
Link to post
I'm a slow learner!!
I need the Code for a 4462 Serial # y 5037052
Thank you very much
Share this post
Link to post
Hi Loren, Sorry to bother you about radio code have seen the amount of responses over the years
Please could you help uno mas time. Have a 2000 Boxter S radio serial #y 5036042 CD-R 220 thanks Janus
Share this post
Link to post
Try 5301
Share this post
Link to post
Try 5301
Share this post
Link to post
Hi Loren,
For my CDR-220    SERIAL#   Y5048014
Thanks Much!
Share this post
Link to post
Hi Loren,
Thanks Much!
Try 1213
Hi Loren,
It worked perfectly thanks so much. Also, I donated again to the forum as I had not done so in a long while so i figured it was time....
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
