pennyporsche
Becker CDR 210
serial # V5007231
1997 Boxter
Can you please help with the code?
Thnaks
AWESOME ! it worked . Many Thanks!
Edited by boxterg
Share this post
Link to post
9 minutes ago, boxterg said:
Becker CDR 210
serial # V5007231
1997 Boxter
Thnaks
Try 1032
Share this post
Link to post
Hi Loren,
Sorry to bug, but do you think you could help with a code?
CDR-220
Serial: X5027889
Thank you!!
Share this post
Link to post
16 minutes ago, Marlon1 said:
Hi Loren,
CDR-220
Serial: X5027889
Thank you!!
Try 2954
Share this post
Link to post
Loren,
Looks like it's working!
1999 Carrera 4
CR-220
SER: X5013406
Thanks in advance for any help!
Paul
Share this post
Link to post
14 minutes ago, Pauly74 said:
Loren,
1999 Carrera 4
CR-220
SER: X5013406
Paul
Try 0610
Share this post
Link to post
Loren,
Hoping for your assistance.  Boxster had battery issue and no radio card with code.  Info here:
2000 Boxster S
Becker
4462
S/N: Y5041879
Your help greatly appreciated
Salto
Share this post
Link to post
1 hour ago, Salto said:
Loren,
2000 Boxster S
Becker
4462
S/N: Y5041879
Salto
Try 0769
Share this post
Link to post
Loren, radio code assistance please
2001 996
Becker CDR 220
Becker 1
Type 4462
Serial number 15089035
many thx in advance
Barry
Share this post
Link to post
2001 996
Becker CDR 220
Becker 1
Type 4462
many thx in advance
Barry
Try 1595
Share this post
Link to post
Loren,
Hoping for your assistance.  Bought a CDR-210 BE2282 from a 993 had battery issue and no radio card with code.  Info here:
Becker
2282
S/N: W5024638
Michael
Share this post
Link to post
7 hours ago, m2000 said:
Loren,
Becker
2282
S/N: W5024638
Michael
Try 0753
Share this post
Link to post
Hoping someone is still actively helping with the stereo codes here. My serial number is W5020369 and the stereo is the CDR-210. there was also an R 3297 not sure what that was but just in case it is important there it is. the Car is a 1998 Boxster, just got it and the stereo looks brand new, but apparently the battery had been disconnected at some point. Thanks for any help in advance!!!
Edited by pwphoto
added info
Share this post
Link to post
Hello. Can you help with lost radio code? Type CDR220, model BE4462, s/n 15075667. Thank you
Share this post
Link to post
Try 0874
Share this post
Link to post
Try 0795
Share this post
Link to post
Thanks Loren. I'll try when I reset the "wait". I thought I had correct numbers but was the card for our 4s. I'll let you know how I make out.
Rick
Share this post
Link to post
Greetings - same issue.  Thank you in advance for any help.
X5023297
BE4462
I really appreciate your assistance.
Randy
Share this post
Link to post
X5023297
BE4462
Randy
Try 2659
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
