pennyporsche
56 minutes ago, jjrebuilders said:
Hello everyone! Can you please help me out I need the code for the following radio:
Model #: BE 2162
Serial#: T5004145
Type: CR 210
Try 0904
Share this post
Link to post
Hey I've lost my radio code can i please get some help? Thank you
Becker
Type 4462
Ser # X5028133
Share this post
Link to post
Becker
Type 4462
Ser # X5028133
Try 9243
Share this post
Link to post
Hey Loren thank you for the fast response, the code you gave me worked but the CD will not eject from the radio, I have another radio i got off ebay that i hope works, could you help me with the code? It's a
Becker
Type 4462
Ser# X5028881
48/98
Thank you again
Share this post
Link to post
Becker
Type 4462
Ser# X5028881
48/98
Thank you again
This is your third request - perhaps you should consider a donation -- so this site will be here when you need it.
Try 9609
Share this post
Link to post
98 boxster
s/n v5017004
becker cdr-210
please help I just purchase this car!
Edited by lorenz
Share this post
Link to post
23 minutes ago, Loren said:
Try 1323
thank you so much for the fast respond and the code did work! very appreciate it!
Share this post
Link to post
Model #: BE 4362
Serial#: X5017231
Type: CR 220
thank you
Share this post
Link to post
Model #: BE 4362
Serial#: X5017231
Type: CR 220
thank you
Try 1032
Share this post
Link to post
Hi everybody! I ve changed my battery and no longer radio et of course no code!!
BOXSTER S 2003
model: CDR 220
Serial: 15008701
Help me please!!
Nicolas
Share this post
Link to post
BOXSTER S 2003
model: CDR 220
Serial: 15008701
Help me please!!
Nicolas
Try 0187
Share this post
Link to post
On 7/19/2016 at 7:53 AM, Loren said:
Try 2659
Worked perfectly.  Your the best!!
Thank you.
Share this post
Link to post
Hi Porsche riders:
I recently bought a Boxster S 2002.
CR-220 Becker radio was not working, I complained and the seller handed to me a second Becker CR-220. Now I have two CR-220,  I will install one and will sell the other at an affordable price to a member in need of one. Please help me with the codes so I can put one to work at least (not sure which one will work), these are the Serial numbers:
UNIT 1
TYPE CCR-220
MOD BE6624
S/N 15004374
UNIT 2
TYPE CCR-220
MODE BE6624
S/N 15004263
Both units show CR-220 on front.
Thank you very much !!
Share this post
Link to post
54 minutes ago, GEORGE S said:
Hi Porsche riders:
UNIT 1
TYPE CCR-220
MOD BE6624
S/N 15004374
UNIT 2
TYPE CCR-220
MODE BE6624
S/N 15004263
Unit 1 try 7073
Unit 2 try 9016
Share this post
Link to post
Need code for 2001 Porsche 2001 Boxster.  Battery replaced and previous owner did not put the radio code on the manual
CDR - 220
Becker
Type-4462
SN - 15086209
24/99
:drive1:
Share this post
Link to post
CDR - 220
Becker
Type-4462
SN - 15086209
24/99
:drive1:
Try 4620
Share this post
Link to post
I have to WAIT for the option for the **** to come back and try the 4620.  Is it 30 minutes or 30 minutes of engine running before I can try again
Share this post
Link to post
16 hours ago, Loren said:
Unit 1 try 7073
Unit 2 try 9016
Loren,
Thank you very much.
Unit 1 code worked fine.
Unit 2 Display panel doesn't work so I do not know if the code works or not, changed the fuse but it didn't help.. I will keep testing other solutions.
I am very pleased having an original device for this car's model working as new.
Best wishes to all.
GEORGE-S
Share this post
Link to post
Need a code for a CDR 220, appreciate the help in the past.
Type 4462
W5002359
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
