pennyporsche
8 minutes ago, Autolink said:
Need a code for a CDR 220, appreciate the help in the past.
Type 4462
W5002359
Try 6829
Share this post
Link to post
Loren, worked perfectly. Was tied up in traffic and what was a bit more than 30 minutes, request for the code came back up. Presets were still there!
Thanks again.
Rick
Share this post
Link to post
Hi folks, excited to have just joined the club with a 996 Arena Red Cab! Could anyone help me with the radio code?
Model: CDR-210
SN: W5024942
Thanks in advance!
Share this post
Link to post
Model: CDR-210
SN: W5024942
Thanks in advance!
Try 2107
Share this post
Link to post
4 minutes ago, Loren said:
Try 2107
Thanks for the quick reply, unfortunately no luck on the code. I'll try contacting Becker or the dealer on Monday.
Share this post
Link to post
Did you follow the instructions in the Lost Radio Code FAQ to get your correct serial number?
Share this post
Link to post
I believe so, I pressed 8 and 0 and then got the number which appeared after "Serial N".
Share this post
Link to post
If you copied the serial number correctly then it should work.
Only other time I have seen it not work was when the radio had a prior repair by a 3rd party.
Share this post
Link to post
Hi. I went to a Porsche dealership today and even they couldn't help me. Hopefully someone here can.
Model:  CDR-220
SN:  X5025381
Share this post
Link to post
Model:  CDR-220
SN:  X5025381
Try 6939
Share this post
Link to post
Don't often use my radio or CD player. Just to show how often I actually turn it on, it was 3 months ago the battery died and I had to replace it.  I recently took a 2 hour trip and decided to try out the radio and CD player and that's when I realized I needed a code. Prior to the battery going dead it did work because I put some CD's in the remote changer and tried it out. Anyhow, I have the CDR-220 and finally obtained my serial number which is - Y5051542, model 4462. It is a 2001 Boxster S. Any suggestions short of going to the dealer to get a code would be appreciated.
Share this post
Link to post
Try 1051
Share this post
Link to post
I also need help
Type:4362
Serial number: 15005 162
Thank you!
Sent from my SM-G935V using Tapatalk
Share this post
Link to post
32 minutes ago, eth2 said:
I also need help
Type:4362
Thank you!
Try 0850
Share this post
Link to post
Try 0850
You are fantastic.
Thank you!
Share this post
Link to post
Hi, this radio is PCM1 996.642.105.02
MLFB : 5WK7801
Serial : PO8010011207/02
SW3.67
I need code.
Thanks.
Share this post
Link to post
MLFB : 5WK7801
SW3.67
I need code.
Thanks.
From the Lost Radio Code FAQ...
" Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/  OPC. The  PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a  PCM code is from a dealer/  OPC. "
Share this post
Link to post
4 minutes ago, florida miles said:
Hi there lost my radio code sorry loren for e-mailing you directly. I'm a newbie and just getting used to this forum. Just bought a 2000 boxster and found no radio code! Bummer.   The unit is a becker cdr220.
Model 4462
Serial y5040147
Thanks for any help in advance.
Try 8354
Share this post
Link to post
Hello
i can't find my radio card code. Had to get a new battery. Could you please help me?
2000 Porsche Boxster
CR220 Becker
BE 4362
W 5003060
Share this post
Link to post
45 minutes ago, Trina said:
Hello
CR220 Becker
BE 4362
W 5003060
Try 9095
Share this post
Link to post
HI, usual story, new battery, no radio code
Becker traffic radio - BE7820
Serial # 55081499
any help you could offer would be greatly appreciated, thanks
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
