pennyporsche
1 hour ago, MarkT said:
HI, usual story, new battery, no radio code
Becker traffic radio - BE7820
Serial # 55081499
any help you could offer would be greatly appreciated, thanks
For 6 preset Traffic Pro...
Try 52231
Share this post
Link to post
2 hours ago, thisisian said:
Hi, Looking for the radio code for a 1997 993.
CR-210
Serial #: T5000077
Many thanks!
Try 4210
Share this post
Link to post
I am really excited to join this great forum.
CDR-220
Model: 4462
Serial: Y5039476
Thanks a lot in advance for the help.
Share this post
Link to post
CDR-220
Model: 4462
Serial: Y5039476
Try 7543
Share this post
Link to post
Same as everyone else new battery.
Cdr-220
Type-4462
s/n -y5053405
Edited by Cukuy
Share this post
Link to post
CDR-220
Model: 4462
Serial: Y5039476
Share this post
Link to post
CDR-220
Model: 4462
Serial: Y5039476
Try 7543
Share this post
Link to post
I am not quite sure if this where I need to post a request for a radio code. Forgive me if this is not the right place.
Becker 1
Type 4462
S/N y5044415
Thank you
Share this post
Link to post
Becker 1
Type 4462
S/N y5044415
Thank you
Try 7401
Share this post
Link to post
I cut and pasted from a previous reply, and I thought I had updated the serial number.  Sorry.
Here is the correct serial number that I need de-coded.
CDR-220
Model: 4462
Serial: X5023179
TIA!
-Stephen-
Share this post
Link to post
Sorry I just found this thread right after sending you a PM, please forgive me.
Porsche-Alpine CD-10 (Euro model of CD-2)
S/No. PO CD10 X 11 11421
B9 11 11421 A
Apparently following these instructions the code is the second line:
Many thanks in advance
Edited by Loren
Removed links to copyriughted materials
Share this post
Link to post
CDR-220
Model: 4462
Serial: X5023179
TIA!
-Stephen-
Try 4546
Share this post
Link to post
B9 11 11421 A
Sorry, I can only decode Becker - Porsche radios.
Share this post
Link to post
48 minutes ago, ddelp95 said:
Hello i have 2000 boxster
cdr-220
type 4462
sn: W5006169
please help me find a code that works:/
Try 0716
Share this post
Link to post
On 8/1/2016 at 6:45 PM, Loren said:
Try 7401
It worked.
Thank you.
Share this post
Link to post
Hi Loren,
I have a CDR-210, type R 2896 and S/N# I5001009.  Can you help me find the radio code?
Thanks.
Brian
Share this post
Link to post
  • Similar Content
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
    • By Douglas Norton
      I have a 2004 Porsche Cayenne S with a Becker radio and Bose system. I understand the radio is a PCM 2. The radio is a CBR23 E1. I had a Bluetooth adapter installed and now my radio immediately goes into PROTECT mode. I tried downloaded the unlock code from an internet service, but there is no place or time for me to enter it in to radio. Any help would be greatly appreciated.
