pennyporsche
12 hours ago, Butch T said:
I am hoping someone can help me.  I have a 2001 Porsche Boxster.  Like many on this forum, when I replaced the battery, the radio stopped working unless I punched in a 4 digit code.  I need help to figure out just what that code might be.  The radio is model CDR 220
Serial # y5052932
Type 4462
Thank you
Try 0903
Share this post
Link to post
11 hours ago, Trina said:
Thank you, Loren. My code didn't work. I again followed the directions from FYI. Now I think I have have the correct info.
2000 Porsche boxster
CPR 2081
4462 15000612 24/99
Again thank you for your support.
Try 4385
Share this post
Link to post
Hello Loren,
I have a 2001 C4 coupe and the number of the cards for navigation and radio are not working.
Could you please help me? I tried
I have 2 different number and blocked both :(
Model: BE 2580
SN:55150128
And another serial number:
SN: P08030205822/04
Many thanks in advance.
Regards,
Raul
Edited by Shattheman
Share this post
Link to post
You obviously did not read the Lost Radio Code FAQ...
Quote
Can you give me a code for my  PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/  OPC. The  PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a  PCM code is from a dealer/  OPC.
Share this post
Link to post
20 minutes ago, Shattheman said:
Sorry, now... yes, I have read it. Is there any way to recover it?
Share this post
Link to post
Looking for radio code for my 2000 boxster s
CDR220
SERIAL NO. X5038446
BECKER 4462
ANY HELP
THANKS
Share this post
Link to post
CDR220
SERIAL NO. X5038446
BECKER 4462
ANY HELP
THANKS
Try 3809
Share this post
Link to post
Greetings!
Like pretty much everyone else, I replaced the battery on my 2001 Boxster and now need the radio code. So glad to find this forum!
CDR-220 / Becker 4462
Ser #: Y5051410
Thank you for the help!
Share this post
Link to post
7 minutes ago, SwervinMervyn said:
Greetings!
Ser #: Y5051410
Try 4596
Share this post
Link to post
Hello, like most had  to replace my battery and have no idea where the code card is.
2001 Boxster S
CR-22
Y5023430
Thank you very much.
Share this post
Link to post
Hi just replace the alternator and do not have the radio code. can you help?
model 4362,  serial 15001555,    24/99
Thank you
2002cars
Share this post
Link to post
2001 Boxster S
CR-22
Y5023430
Try 0792
Share this post
Link to post
Thank you
2002cars
Try 0165
Share this post
Link to post
25 minutes ago, shannonevo said:
Loren
can you please help with my CDR 220
type 4462   24/99
ser# 15009141
Shannon
Try 6027
Share this post
Link to post
3 hours ago, Mike Watts said:
I have replaced battery in a newly purchased Porsche Boxster S reg VU03PNJ Radio is CDR22 can you help?
Please read the Lost Radio Code FAQ to follow the procedure to get your radio's serial number.
Share this post
Link to post
Serial number is 25008878 !!
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
