pennyporsche
You are amazing. Thanks!
Same and common issue.. why doesn't owners write this code down in the manual or something. Hope you can help
Becker 4462
radio SN Y5046187..
I tried 6401, 6403, 6404
I am back to wait..
Wayne
Try 0860
or
0858
Just like magic.. you are great.. the first code worked.. THANKS
Share this post
Link to post
Hi, I have a 99 Boxter with locked stereo after disconnecting the battery for transport...
Becker 1
Type 4462
Ser X5021372
Any help would be greatly appreciated!!
Try 0706
or
0704
0708 did the trick (as per your FAQ). Thanks!
Share this post
Link to post
I wonder if anyone would be kind enough to help me... I have fallen victim to the lost radio code conundrum after a battery failure.
The car is an '01 S
The stereo is: CDR-220
Serial: Y5024619
Series: 4362
Any help figuring this out would be much appreciated.
Cheers!
Share this post
Link to post
The car is an '01 S
Serial: Y5024619
Series: 4362
Cheers!
Try 0601
or
0599
Share this post
Link to post
The car is an '01 S
Serial: Y5024619
Series: 4362
Cheers!
Try 0601
or
0599
0601 was the ticket.
Thanks so much.
Share this post
Link to post
Had to disconnect my battery and now the radio is locked.
CDR-220
4462
X5025056
Thanks in advance.
Share this post
Link to post
CDR-220
4462
X5025056
Thanks in advance.
Try 9185
or
9193
Thanks for the quick reply, Loren. Neither of those codes worked...any other suggestions?
Share this post
Link to post
My battery died and now my radio is locked:
2002 Boxster S
Becker 1
Type 4462
Serial 15088261
24/99
CDP2081
Thanks a lot!
Share this post
Link to post
Help appreciated. I'm in the same boat as others, purchased vehicle without radio code, after disconnecting the battery I need the code.
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
will provide vehicle vin if needed
thanks
Share this post
Link to post
2002 Boxster S
Becker 1
Type 4462
Serial 15088261
24/99
CDP2081
Thanks a lot!
Try 5160
or
5158
Share this post
Link to post
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
thanks
Try 7375
or
7371
Share this post
Link to post
Just had the original battery replaced in the 97 Boxster I bought a year ago and, of course, unable to locate the radio code card. The forums have been a great help in finding the s/n and I'm hopeful that I can get the 4-digit code so I can enjoy some tunes during the great summer weather.
'97 Boxster (German vehicle brought into US)
Radio is a CR-21 with a 6 disc changer in front trunk.
Model R1996
S/N V5002786
Hope you can help with a code.
Thanks.
Try 2565
or
2563
Thanks Loren. Unfortunately I tried 2560 through 2569 and no luck. Is there anything else I can try?
Share this post
Link to post
Model R1996
S/N V5002786
Thanks.
Try 2565
or
2563
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Share this post
Link to post
Thank you, I am greatful for the tip. I will have to 'wait' to try the variances that you suggest in earlier posts.
The dealer I purchased the car from has yet to get back to me with any info (it has only been a day, but i got an answer here in an hour or so)
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
thanks
Try 7375
or
7371
Share this post
Link to post
Hello
My SN is V5015965, CDR-210 from '98 Carrera S.
Thanks in advance.
Jeff
Try 1099
or
1097
Nope, neither worked. In fact, the dealer gave me Code 2101 based on SN and VIN and it doesn't work.
Any suggestions?
Share this post
Link to post
ok, followed the steps and this is wat i came up with:
type: 4462
cdr-220
srl#: w5006540
thanks u so much
Try 5188
or
5186
both didnt work :s
Share this post
Link to post
Man, I hate to ask since this radio-code thread has really overburdened Loren. But here goes...
Becker 1 CDR-220
4462
Y5053643
Can you help out yet another enthusiast trying to return tunes to his travels? Thanks, thanks, thanks.
Joe
St. Louis, MO
2001 Boxster
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
