pennyporsche
It worked like a charm, many thanks! Any idea if the CR 210 model i gave you in an AUX model or CD changer model ? THANKS!!
Share this post
Link to post
Just now, RustyGasket said:
Hi Loren,
Would you be so kind? Need the code after a dead battery.
CDR 220
Type 4462
Serial # 15062841
24/99
Thanks in advance
Try 6590
Share this post
Link to post
Hi Loren.  I would really appreciate your help.  Had the code card so disconnected the radio. Turns out my card isn't for my radio.
Typ: CDR 220
Model-No.: BE 4462
Serial-No.: X5026102
48/98
thank you
Share this post
Link to post
Typ: CDR 220
Model-No.: BE 4462
48/98
thank you
Try 9365
Share this post
Link to post
8 hours ago, Loren said:
Typ: CDR 220
Model-No.: BE 4462
48/98
thank you
Try 9365
Thank you Loren!  You're a genius, a life-saver and did I mention - you're a genius! :).
Thank you!!!
Share this post
Link to post
Hi Loren,   really would appreciate your help mate.    Got an old 2000 911 Carrera and after an engine rebuild nobody can remember the code and cannot locate the card where it was recorded.
Using instructions I found on the net I can say it is a Becker
Model 4367
Serial Y5022093
Any help you can give would be much appreciated
Thank you
Share this post
Link to post
Hello Loren,
I wasnt aware i would need a radio code when i changed my battery. My radio screen is going out but it think i managed to get the serial number.
4462
X5030040
48/98
Thanks!!
Share this post
Link to post
Model 4367
Serial Y5022093
Thank you
Try 0364
Share this post
Link to post
3 hours ago, 4thgendj said:
Hello Loren,
4462
X5030040
48/98
Thanks!!
Try 0320
Share this post
Link to post
Can you please help me with my radio code
Beker cdr 220
4362
ser # 15004648
24/99
Can any one help.....thank you
Share this post
Link to post
Beker cdr 220
4362
ser # 15004648
24/99
Try 0843
Share this post
Link to post
5 minutes ago, bmo72 said:
cdr23
model be 6627
serial: 55036243
thank you
Brian
You obviously did not read the Lost Radio Code FAQ - read this first
" CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected. "
Share this post
Link to post
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR 220
type BE 4362
serial # 15004648
Thanks for your help :)
Share this post
Link to post
22 minutes ago, richardm said:
Hello,
Becker CDR 220
type BE 4362
serial # 15004648
Try 0843
Share this post
Link to post
9 minutes ago, richardm said:
the code did not work.....can we try another maybe ....thanks so much anyways
Did you use the procedure in the Lost Radio Code FAQ to get your correct serial number?
If not, please do so and then post again here.
Share this post
Link to post
I checked the info
BEKER 1
4362
ser # 15004648
24/99
Vin # WP0CA29902S652809
CODE 3 0843 DID NOT WORK.......THANKYOU SO MUCH FOR THE HELP
Share this post
Link to post
19 hours ago, Loren said:
Try 0364
Loren,    thank you so much it worked a treat.   Many many thanks for your help
Aardvaark
Share this post
Link to post
2 hours ago, richardm said:
I checked the info
BEKER 1
4362
ser # 15004648
24/99
Sorry, I can not help you then.
Share this post
Link to post
2000 Boxster S
CDR-220
type: 4462
Serial: Y5035660
VIN: YU663144
Thank you...
Edited by Jimc23
forgot item
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
