pennyporsche
Hello,
I'm looking for a radio code for:
2001 Boxster
Radio:  CDR 220
Type: 4462
Serial: Y5050571
Thanks in advance!
Ron
Share this post
Link to post
On 11/24/2016 at 9:33 PM, Loren said:
Try 4809
Thank you so much, That is what I have written down from the PO, but it does not work.  Thanks anyway for the help, it is very nice of you.
Share this post
Link to post
6 hours ago, Rottenbind said:
Hello,
2001 Boxster
Radio:  CDR 220
Type: 4462
Serial: Y5050571
Thanks in advance!
Ron
Try 0473
Share this post
Link to post
3 hours ago, Ronny Pettersen said:
Hi, id appreciate recovering the code from a 2000 996 turbo
Radio: cdr-22
Type: BE 4467
Serial: Y5026898
Try 3206
Share this post
Link to post
Did you use the procedure in the Lost Radio Code FAQ to get the correct serial number of your radio?
If not, then please do so and report the correct serial number here.
Share this post
Link to post
11 hours ago, Rottenbind said:
Hello,
2001 Boxster
Radio:  CDR 220
Type: 4462
Serial: Y5050571
Thanks in advance!
Ron
4 hours ago, Loren said:
Try 0473
Thanks Lauren!  I really appreciate the help.
Ron
Share this post
Link to post
34 minutes ago, MarkAwe said:
I have a Becker CR 210 in a 1998 Boxster.  Just changed out the battery and lost the code.
The SN is W5023429
Try 0784
Share this post
Link to post
Hi, I hope someone can help.
I had disconnected the battery in my Boxster 1998 and now the radio code that I had doesn´t work (8452).
CR-210/CDR-210 Becker   Serial N: W50221208      R3297
Thanks in advance.
DR 90210
Share this post
Link to post
Thanks in advance.
DR 90210
Try 8642
Share this post
Link to post
On 11/24/2016 at 9:37 PM, Loren said:
Try 3684
Thank you VERY much Loren! This is a GREAT site. I'm very glad I found it. Thanks again!!!!
Share this post
Link to post
Hi, I´d try and did´t work :helpsmilie:
Share this post
Link to post
Hello,
Recently disconnected my battery and need help with a radio code.
Radio:  CDR 210
Type:2896
Serial: V5007961
Thank in advance!
Share this post
Link to post
22 minutes ago, wink6312 said:
Hello,
Radio:  CDR 210
Type:2896
Serial: V5007961
Thank in advance!
Try 7104
Share this post
Link to post
Yes, I did
thanks in advance
Share this post
Link to post
Battery removed and code is lost.
CDR220
model be6625
ser # 15009674
Share this post
Link to post
Hi, I hope someone can help. I had disconnected the battery in my Boxster 1998 and now the radio code that I had doesn´t work (8452).
Serial N: W50221208
R3297
Thanks in advance. DR 90210
Share this post
Link to post
Serial N: W50221208
R3297
Try 8642
Share this post
Link to post
Yes, I did .
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
