pennyporsche
Hello,
Could someone help me with radio unlock code for my project car, a Boxster 986 from year 2000.
Radio serial number is X5020852 and type is 4462 (CDR-220).
With best regards,
Henry
Edited by DiyEvBoxster
Share this post
Link to post
3 hours ago, DiyEvBoxster said:
Hello,
With best regards,
Henry
Try 0643
Share this post
Link to post
Good Afternoon
Could anyone help me with a radio code?
1998 Boxster
CDR-210
PR-VERS
R 2896
SERIAL - N
V5010273
Share this post
Link to post
1 hour ago, lvanover said:
Good Afternoon
1998 Boxster
CDR-210
PR-VERS
R 2896
SERIAL - N
V5010273
Try 6521
Share this post
Link to post
Hi I have a CDR 220  Model BE 6625
Serial 25010348
took the radio out to work on the a/c and since its a 2002 boxster I have no idea the code to get back into the radio, sigh.
Can you help?
Share this post
Link to post
Serial 25010348
Can you help?
Try 0706
Share this post
Link to post
2 hours ago, rare_spares said:
Loren, would you be able to help me with a missing code as well?
01 996.1
CR220
Type 4362
Ser# X5018762
Thanks, Chris
Try 1489
Share this post
Link to post
2 hours ago, Steve Johnstone said:
Hello Loren,
I'd appreciate your help with this.
Becker CDR 22
Type 4467
Serial no: 25010085
Thanks in advance.
Steve
Try 4264
Share this post
Link to post
hi,  My radio needs the code due to the battery cable being removed..
cdr-220
BE 4462
X5025943
Can anyone help?
Thanks!  Mark
Edited by mra8118
Share this post
Link to post
cdr-220
BE 4462
X5025943
Can anyone help?
Thanks!  Mark
Try 7340
Share this post
Link to post
hi
i changed by battery and dont have the radio code
it is a becker cdr 220 ser.X5026660
can anyone help here????  Thanks in advance for your assistance!!
Sorry just saw your response - I edited to correct # cr220.....  (need my glasses!...)
Edited by tonyhill
cdr 220
Share this post
Link to post
  • Similar Content
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
