pennyporsche
13 minutes ago, Loren said:
Try 5087
I turn the radio on and it gives me "wait" is there anyway to go around this to input the code or how long do I have to wait for?
Share this post
Link to post
1 hour ago, manu_ac said:
Hi.
My CR-22 serial is: BE4367 Y5022257
What is the code ?
Thanks for your help :-)
Try 2429
Share this post
Link to post
Bought a used CDR-220 and would like to get the code. Radio serial is X5030410
Thanks in advance
Share this post
Link to post
Thanks in advance
Try 4786
Share this post
Link to post
2 hours ago, Paulwithey1966 said:
1999 Boxster
CR-22
4367
15040105
Any help would be appreciated.
Paul
Try 5424
Share this post
Link to post
19 minutes ago, texas996 said:
Missing code please help if you can.
2001 Carrera 4s
CDR 220
BE 4462
Sn: Y5050207
Try 2409
Share this post
Link to post
Hey looking for missing radio code, please help. SERI# Y5023895
        BECK 1
        TYPE 4362
        CR220
Thank you
Share this post
Link to post
        BECK 1
        TYPE 4362
        CR220
Thank you
Try 6832
Share this post
Link to post
Hi Loren,
I replaced The broken PCM 2.0 to a 2.1, it's working but the other modules as tel. amp, Nav, have different version and need to be updated to earlier version, software shows 4.0.No CDs! I have IPAS codes for my car, but the new PCM showing its own VIN, could it be modified by PIWIS to the cars VIN than using my IPAS codes? or I have to own new IPAS for its VIN? Thank You
Share this post
Link to post
45 minutes ago, FHS72 said:
Hi Loren,
You should be able to change this in PIWIS.
Share this post
Link to post
I've tried to change it, but I'm getting an error message! maybe i'm doing something wrong? That's why i'm asking, I thought that it couldn't be changed.
Share this post
Link to post
This is not a Lost Radio Code - please continue this in a new post giving model and year of your car - and what was done.
Share this post
Link to post
Ok, Thank You Loren.. Will do it later.
Share this post
Link to post
Hi, Loren... Got the serial number from my Becker using the instructions in the FAQ (Thanks!).
Can you tell me what the code is for X5038296?
Thanks for any info.
-Doug
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
