pennyporsche
I have lost my radio code and do not have the card. It is a 2001 Boxster with a Becker 220 and the Type is 4462 the serial number is Y5052656 and displays a 24/99.
Try 4355
or
4357
Share this post
Link to post
PLEASE HELP!!!
I need a 4 digit code for my 1999 boxster radio.
BECKER 1
TYPE: 4462
SERIAL #: W5008265
Thanks in advance.
Try 5190
or
5192
Thank you Loren! I will try and let you know the outcome...THANKS AGAIN! :)
5192 works GREAT!
thanks a million! :rolleyes:
by the way, which decoder program are you using?
Share this post
Link to post
Battery removed and radio code lost.
CDR220
model be6625
ser # 25010596
ec102
Thank you.
Tom
Try 4255
or
4257
57 Worked thank you.
ATB,
tom
Share this post
Link to post
Hi Loren, could you please, kindly, help me obtaining the radio code for my 99 Boxster? It's VIN is WP0ZZZ98ZXS604255
Radio: CDR-220
Model: 4362
Serial Number: X5010943
I'm just tired that my Porsche dealer in Chile says that he needs to ask for it to Germany... it has been almost 2 weeks... too much, or not? :huh:
Kindest regards, and many thanks.
Juan Eduardo
Share this post
Link to post
Radio: CDR-220
Model: 4362
Juan Eduardo
Try 4593
or
4591
Share this post
Link to post
I am new to this so be patient.
I am in need of my radio code
I have just bought another 2001 boxster s
radio: cdr220
radio ser#: 15076978
model: BE 4462
Please Help.
Share this post
Link to post
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Share this post
Link to post
Loren
Would you please help
I'm driving a 1998 porsche boxster with a CDR-210
the serial # is V5015340 and model # R3297
I need the radio code
George
Share this post
Link to post
Loren
George
Try 3026
or 3024
Share this post
Link to post
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Thanks, That did the trick.
Share this post
Link to post
Hi, usual story, lost Code
Becker 1 CDR 200 - 4467
#Y5026257
Greatly Appreciated.
Try 5004
or
5002
Sorry, didnt seem to work (and I meant to put Becker 220, dunno if that makes any difference?
Share this post
Link to post
Radio: CDR-220
Model: 4362
Juan Eduardo
Try 4593
or
4591
Soory, they didn't worked and I've found that the radio is a CR-220, does it chanhe the codes that you gave me? Many thanks!!! is incredible your support! Kindest regards.
Juan Eduardo
Share this post
Link to post
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Loren,
It seems that I was mistaken the 1011 or 1013 code does not work.
I have checked and my radio ser# is correct (15076978)
Would you be so kind as to check for the code again.
Thank you.
Share this post
Link to post
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Loren,
Thank you.
1013 is the code that I come up with - try codes 2 digits different from that code (i.e. 1011, 1009, 1015, 1017. etc.)
Share this post
Link to post
Loren
George
Try 3026
or 3024
Loren
I did try 3026 and 3024
but they don't work?
1998 boxster with a becker radio CDR 210
serial # V5015340
model R 3297
Would you please try again
Share this post
Link to post
Loren
George
Try 3026
or 3024
Loren
serial # V5015340
model R 3297
I got thew same result.
My program does not always work. It works maybe 95% of the time but I have no expanation why it doesn't always work.
At this point you will need to contact a dealer or Becker. Becker charges to lookup your code and some dealers do too.
Share this post
Link to post
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Loren,
Thank you.
Thank you it was 1015 and the radio is up and running.
Share this post
Link to post
hI THERE
Please i need the code for my cdr210
model no: be2282 serial v5016205
thanks in advance
Didn't work ! any other options thanks
and sorry for the pm take care
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
