pennyporsche
Hi, just replaced battery in my 98 boxster but now radio asking for a code. It's a cdr210, Becker r3297 serial 208012515382076235. Any help would so greatly appreciated. Thanks in advance !
Share this post
Link to post
On 8/17/2017 at 4:01 AM, lukecufc said:
Hi I could really do with some help after no radio for 2 months!
Type: cdr22
model no.: be6621
seriel number: 15005215
thank you very much in advance
Try 4858
Share this post
Link to post
That is the longest serial number I have ever seen on a Becker/Porsche radio - I hope it is correct.
Try 4828
Share this post
Link to post
Loren, thanks for your quick response. I put the code 4828 in and clicked the down arrow and now it is just displaying a WAIT message. Does that tell you anything? To confirm, I got the serial number offf the back of the faceplate. Is this the correct place to look?
I really aprecciate your help with this
Share this post
Link to post
Seems like the radio now won't say anything besides "wait". I don't mind waiting but wondering which direction this is goin in...
Share this post
Link to post
Thank you, Loren. I apologize for the rookie mistake! Read it the first time but not far enough, my bad...
Once the "wait" is over I will re-attempt this procedure. Thanks again for your assistance
Share this post
Link to post
5 hours ago, Will.Escobar said:
Had battery replaced and need stereo code.
its a CDR220 SN Y5024512.
any help would be appreciated.
Try 5346
Share this post
Link to post
Hi Loren. Ok I think I have it right this time. CDR 210 , 98 boxster, Becker, serial V5015015. Fingers crossed !
Thank you
Share this post
Link to post
Thank you
Try 5275
Share this post
Link to post
That did it. You are great, sir! And lightning fast too. PM me if you would like some compensation for the help.
igor
Share this post
Link to post
Need help with a lost code.
Model - 6624
ser# - 15004332
On a side note, I have an  02 S with the Bose stereo and the CR220 is not working but we swapped it out with a CDR220 and now no sound comes out. Are they not compatible?
Boxster S that is
Share this post
Link to post
Model - 6624
ser# - 15004332
Boxster S that is
Try 3153
Share this post
Link to post
Hi Loren,
if it's not too much trouble can you check my radio code please?
1998 911 cab C4
It's a CDR210
R3297
V5016027
thanks Loren
Share this post
Link to post
20 minutes ago, Hibbsy7 said:
Hi Loren,
1998 911 cab C4
It's a CDR210
R3297
V5016027
thanks Loren
Try 5181
  • Like 1
Share this post
Link to post
Had to replace my fuel sender unit so the battery had to be disconnected. Of coarse code is nowhere to be found.
Type 4462
serial number x5016156
Share this post
Link to post
Type 4462
Try 0612
Share this post
Link to post
Hi Loren,
I have a 2000 boxster that needed the airbag/horn bushings beefed up which is now great but radio codes lost.
It's a type 4462 ser# Y5039259  24/99.
Hoping you can help.
Terre
Share this post
Link to post
Help Please! Lost radio code Becker CDR 220, BE 4462 Serial Number Y5043788. Im guessing that there are zeros in the serial number.
Thanks in advance! Trying to listen to some music today.
Share this post
Link to post
3 hours ago, TURBOKING7622 said:
Hi Loren,
Terre
Try 1370
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
