pennyporsche
1 hour ago, Euroah said:
Hi, 1996 993 with CDR-210 Version R3297 Ser# WS021147   Needing radio code.  Thanks,  Greg
Try 4570
Share this post
Link to post
7 hours ago, Boeingone said:
I have a 1998 993 and need the radio code.
It’s a
CR-210
SN V5001981
PR- vers R 3297
1
Try 5069
Share this post
Link to post
I have a 2001 Boxster and need the radio code
Becker 1
CDR-220
Type 4462
SN Y5061128
24/99
Thank you!
Share this post
Link to post
CR-2200
Type 4466
Serial 15000354
Hope, the serial is correct. Others seem to have a letter in front.
Share this post
Link to post
It’s a
CR-210
SN V5001981
PR- vers R 3297
 Oops, made a slight mistake on the serial number of the radio. It should be V5007981.
 If you could send me the radio code for that  serial number it would be greatly appreciated.
Randy
Share this post
Link to post
5 hours ago, piethein said:
2002 996.2
CR-2200
Type 4466
Serial 15000354
Try 0754
Share this post
Link to post
Randy
Try 7264
Share this post
Link to post
Becker 1
CDR-220
Type 4462
SN Y5061128
24/99
Thank you!
Share this post
Link to post
10 hours ago, Loren said:
Try 0754
Thank you.
Just got the car, so the instant I saw that code from you, I knew what the hand written number in the option sticker was for... Doh!!!
BR,
Jussi
Share this post
Link to post
Becker 1
CDR-220
Type 4462
SN Y5061128
24/99
Thank you!
Try 5418
Share this post
Link to post
Could you please provide me the code to;
CDR-220
BE 4462
Serial # 15088214
Thanks in advance.
Share this post
Link to post
CDR-220
BE 4462
Serial # 15088214
Thanks in advance.
I just gave you a code for a (different) radio on Sunday... what's up?
Share this post
Link to post
The radio didn’t work, the face lit up but remained blank. I took it back to the place and they gave me another one.
It was a CCR instead of a CDR maybe that had something to do with it.
Edited by JH2000
Share this post
Link to post
CDR-220
BE 4462
Serial # 15088214
Thanks in advance.
Try 1210
Share this post
Link to post
Hi, i just bought a 996 turbo and the PO replaced the battery but he says when he went to hook up new battery and start the car, the radio asked for a code. The code that the book has as well as the code the dealer provides doesn't seem to work.
The unit is a Seimens/Becker PCM1 and the serial number is BE2582Y5007982
Unit model is a 2582
I will be calling Porsche corpporate or Becker corporate tomorrow but just thought i'd ask if someone on here might be able to find the code.
thanks
-evan
Share this post
Link to post
I had to replace the battery on my 986 and couldnt find the radio code anywhere.
Could you please provide it?
CR-22
Serial 25002294
Type 4367
24/99
Thank you so much!
Share this post
Link to post
thanks
-evan
You did not read the
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
