pennyporsche
On 4/30/2018 at 5:55 AM, Loren said:
You did not read the
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi Loren. Sorry about that, i think i read that bit after i posted.
Apparently retrieving the code from a PCM1 is no trivial task. After paying the dealer a visit, they provided me with the codes that corresponded to the VIN, which didn't work. So then they suggested calling Porsche NA (1-800-Porsche) which they turned me back around and told me to talk to the dealer. Called dealer again and got to emailing with a tech. He tried to email porsche NA directly with my radio serial number. Porsche NA came back and told him that they needed more info, so now i have to physically drop the car off at the service center so the tech can hook the radio up to their diagnostic testing hardware and pull more information from it.
The one thing the tech did tell me is that, if you have a PCM and you take it to your nearest Porsche dealer, and they don't know what to do, he said to tell them the following:
Submit a PTEC - TLAR for filing issues, and PQIS job and run VAL attached to PTEC request.
Im not sure what any of the above means but for those of you who are struggling with your dealer in retrieving a PCM1 code, tell them to try that.
Share this post
Link to post
7 hours ago, Sebri said:
Hi Guys hope you can help me
Code for
serial No: V5007071
Radio model please (on the front of the radio)?
Share this post
Link to post
16 minutes ago, Sebri said:
Yes i did i used the 8 and 0 simultaneously and got my Sireal NO
Then it is likely that your radio has been repaired by someone other than Becker. Doing so changes the serial number and without them updating it properly I do not know any way to get the "unknown" serial number. Sorry.
Share this post
Link to post
Hello,
First off I would like to thank you for providing this service... you are lifesavers.
2000 Boxster
CDP2051
24/99
Ser: 25010876
Type: 4462
Share this post
Link to post
2 minutes ago, randykieling said:
Hello,
2000 Boxster
CDP2051
24/99
Ser: 25010876
Type: 4462
Try 0835
Share this post
Link to post
wow!
you are on the ball. I figured it would take a while so I posted from work.
I will try that code as soon as I get off work.
thank you very much
Randy
Share this post
Link to post
any help would be greatly appreciated.  Just bought an old 1999 porsche with a dead battery and no radio code provided.
cdr 220
4463
W5012352
thanks in advance to anyone that can provide a good code.
Share this post
Link to post
My battery in my 2001 Boxster went dead.  Now I need the code to get the radio working again.
Radio: CDR 220
Type : 4462
S#:  Y5052581
Share this post
Link to post
cdr 220
4463
W5012352
Try 6873
Share this post
Link to post
Radio: CDR 220
Type : 4462
S#:  Y5052581
Try 0173
Share this post
Link to post
Help hugely appreciated. Dead battery = no radio
CR 22
Serial X5020324
Type 4367
Edited by T4toria
Share this post
Link to post
15 hours ago, Loren said:
Try 0835
worked great...
off to make a donation for your help
thanks again
Randy
Share this post
Link to post
Hello Loren,
Pls help me obtaining the radio code for:
1999 Porsche Boxter
Radio Type: 4462
SN: 15075111
24/99
Gal: 00
CD: CDP 2081
Thank you so much.
Share this post
Link to post
CR 22
Serial X5020324
Type 4367
Try 0514
Share this post
Link to post
13 minutes ago, E Phuong Ho said:
Hello Loren,
1999 Porsche Boxter
Radio Type: 4462
SN: 15075111
24/99
Gal: 00
CD: CDP 2081
Thank you so much.
Try 9627
Share this post
Link to post
2002 Porsche Boxster
I have a CDR 220
Ser# 15002270
Becker type 4462
Need the radio code please.  After a really dead battery.
Thank you in advance.
Edited by Acha n.v ak
Share this post
Link to post
I have a CDR 220
Ser# 15002270
Becker type 4462
Try 2543
  • Thanks 1
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
