pennyporsche
I am missing the code to my radio.  Any help would definitely be appreciated.
Radio type is 4462
s/n: 15086415
Thank you,
Adam
Share this post
Link to post
Radio type is 4462
s/n: 15086415
Thank you,
Adam
Try 7021
Share this post
Link to post
I'm Porsche newbie. graduated from Mercedes. I swapped out my batter on my 99 boxster and now i need a code. I've following a few threads and looks like i can get some hlep from you nice porsche owners.
Here's the radio info i got.
Ser# W5022344
Type 3297
Share this post
Link to post
Ser# W5022344
Type 3297
Try 6709
Share this post
Link to post
4 hours ago, mikederge said:
Just changed my battery and don't have code for 97 Boxster
CR210 V5004873  850276
Thanks in advance
Usually there are no spaces in serial numbers.
If your serial number is: V5004873
Try 6970
If your serial number is: V5004873  850276
Try 6545
  • Like 1
Share this post
Link to post
3 hours ago, Loren said:
Try 6729
No luck yet.
If it's any help, the radio type is 3297
Thanks anyway!
Edited by Calvin Goldschmidt
Added info.
Share this post
Link to post
2 hours ago, Loren said:
Did you follow the procedure to get the correct serial in the Lost Radio Code FAQ?
I sure did. Was going to send picture of the ser # I grabbed from the radio after accessing the ser # menu area. but file size was to large. I def have the ser # correct. No worries though. Thanks for trying.
Share this post
Link to post
Try 4685 (I may have made a typo)
Share this post
Link to post
2 hours ago, Calvin Goldschmidt said:
Sorry. Still not working. Again, I appreciate you trying.
Well then chances are that your radio has been repaired by a 3rd party (not Becker).
In that case I am sorry I can not help.
Share this post
Link to post
Thanks again for trying.
Share this post
Link to post
29 minutes ago, MechanicalEng said:
Hi Loren, could you please find my code?
CR220
Type 4362
Serial# 15031464
Thank you so much!
Try 5028
Share this post
Link to post
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR - 22
type  4467
serial # 15055546
Thanks for your help ?
Share this post
Link to post
Next time, I will keep the maintainer on the battery when I change it.
Becker CR-220
Type 4362
serial #  15004875
Thank you!
Edited by alfonse
Share this post
Link to post
11 hours ago, Yorkshire Paul said:
Hello,
Becker CDR - 22
type  4467
serial # 15055546
Try 5428
  • Like 1
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
