pennyporsche
Looking for the code for cdr 220 type 4462
ser no 150 764 14
thanks for any help!
Share this post
Link to post
1 hour ago, tacdriver904 said:
Hey Loren,
Your help is greatly appreciated...
1998 Boxster
CDR 210
Model: BE 2282
SN: W5018439
Thank you very much for helping all of us out!
Try 3753
Share this post
Link to post
12 hours ago, Loren said:
What is the model number on the front of your radio?
I just took the head unit out, and found the model and serial number: BE 2580 - 15085884
Can anyone please help to generate the 4 digit code? thank you and much appreciated.
Share this post
Link to post
Did you read the Lost Radio Code FAQ?
That is a PCM unit.
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
  • Like 1
Share this post
Link to post
That is a PCM unit.
thanks Loren, guess I have to spend $200 for just the 2 codes at the authorized garage.
Share this post
Link to post
Can you help with my C4 2001 radio code?
I have a cdr 220 serial number 15076414
Thank you in advance!
Rusty
Share this post
Link to post
Rusty
Try 7013
Share this post
Link to post
13 hours ago, Loren said:
Did you follow the procedure in the Lost Radio Code FAQ to get the correct serial number?
Hi Loren yes I pushed TP for 10 seconds and Becker appeared and I turned smoothly the right knob till I get the serial nbr which I sent here previously
than I tried 0519 but it didn't work
Share this post
Link to post
Any suggestion or nbr pls?
Share this post
Link to post
If the number I gave you did not work then it is likely that your radio has been repaired by a third party (not Becker) and the serial number was changed.
I am sorry but in this case, I can not help you - only Becker can correct the issue.
Share this post
Link to post
Hi, would you happen to have the radio code for my:
1999 911
Becker
Type CDR 220
Model No BE 4462
Serial No W5009586
*4462KF0W5009586*
Thank you very much.
Alice
Share this post
Link to post
1999 911
Becker
Type CDR 220
Model No BE 4462
Serial No W5009586
*4462KF0W5009586*
Alice
Try 1908
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
