pennyporsche
1 hour ago, RMC Motorcars said:
Hi I have a 1998 Carrera 993 vin# WP0CA2990WS340852 need the radio code.
Please read the Lost Radio Code FAQ and follow the procedure there. The VIN does nothing for radio code - since changed could have been changed out numerous times.
Share this post
Link to post
Hello! Had to disconnect my battery today to do some work to the 2002 986.
Becker CDR-220
Type: 4462
Serial: 250 10 195
Thanks in advance for any help!
Edited by Daviddelpauley
I wanted to include additional information
Share this post
Link to post
Becker CDR-220
Type: 4462
Serial: 250 10 195
Try 2313
Share this post
Link to post
Hello! Had to disconnect my battery 2000 986, and i lost my radio code, any ideas anyone?
Becker CDR-220
Type: 4467
Serial: 150 03 591
Share this post
Link to post
Becker CDR-220
Type: 4467
Serial: 150 03 591
Try 1063
Share this post
Link to post
Hello there,
I have a 1999 Boxter Cabriolet and am hoping to get the radio code.  It's a CDR-220 - 4461 Becker 1, and the serial code is: X9016191.  Are you able to help?
Thanks for your time.  ?
Share this post
Link to post
13 minutes ago, T L said:
Hello there,
1
Try 0892
Share this post
Link to post
Glad I found renntech - I just bought a 2000 Porsche 911 Carrara 2 and the battery was flat.  Bought a new one and all good - except the radio.  After reading this string I see there is hope!
I found this - Becker radio - Model #4362 - Ser# Y5021220.  I'd really appreciate your help getting this working again!
Les
Share this post
Link to post
Les
Try 2323
Share this post
Link to post
49 minutes ago, gary w said:
Hello, little help with serial # X5035219
...please.
Model number on the front of your radio, please?
Share this post
Link to post
16 hours ago, Loren said:
Try 0892
I appreciate your help, but that one didn't work. ?  Any other ideas?
Share this post
Link to post
Did you follow the procedure in the Lost Radio Code FAQ to find your correct serial number?
If not, please do so and re-submit the correct serial number.
If you did follow the procedure then chances are that your radio was repaired by a third party (other than Becker) - in that case, I can not help you.
Share this post
Link to post
17 hours ago, Loren said:
Try 0892
I tried again and it worked.  Thanks!
Share this post
Link to post
Hi Loren,
Looking for a radio code for the following:
Becker CR 210
Model BE 2182
Serial No V5009123
Thanks in advance.
Share this post
Link to post
19 minutes ago, Shdwfx said:
Hi Loren,
Becker CR 210
Model BE 2182
Serial No V5009123
Thanks in advance.
Try 5983
Share this post
Link to post
On 10/3/2018 at 4:18 PM, T L said:
Hello there,
Thanks again for this code...  Is there a way to make a donation for your time?
Share this post
Link to post
Share this post
Link to post
Yes, just click on "Donate" link at the top or bottom of any page.
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
