pennyporsche
Hi Loren,
Chasing code for:
Becker CDR 220
BE 4462
X5037993
Many thanks in advance ?
Kind Regards,
Matt
Share this post
Link to post
17 minutes ago, BoostDR said:
Hi Loren,
Chasing code for:
Becker CDR 220
BE 4462
X5037993
Kind Regards,
Matt
Try 7360
Share this post
Link to post
Can you help with a radio code for  2001 Boxster? Becker radio CDR 220 Model BE 4462
Serial Number X5 031767
Thank you so much!
Peter
Share this post
Link to post
Thank you so much!
Peter
Try 2604
Share this post
Link to post
Hi Lost my code and disconnected the battery
CDR220
Serial number X5018516
Thanks if you can help!
Share this post
Link to post
CDR220
Try 1538
Share this post
Link to post
Thank you Loren,
Yes, that did the trick! Thank you. There is one small thing, there is no sound coming from the speakers I fiddled with the fade and direction but nothing. Can you tell me if the speakers are fused separately on the 2001 Boxster? am I missing something simple? (The radio worked fine before the power disconnection). PS the convertible top motor has also quit. I haven't been able to troubleshoot that yet either. Feeling foolish:>)
Thank you so much!
Peter
Share this post
Link to post
I bought a replecement cdr 220 from e-bay. The sec code send by the seller didn't work. (and he doesn't respond to my e-mails :-() Hoping to retrieve a code from you guys.
CDR 220
Model-no: BE 4462
Serial-no: Y5035530
Tnx!
Share this post
Link to post
3 hours ago, Marco Ter Voorde said:
CDR 220
Model-no: BE 4462
Serial-no: Y5035530
Tnx!
2
Try 5310
Share this post
Link to post
Another code chaser ...
Brand: Becker
Model: CR 210 - BE 2182
Serial: U5006497
Any help would be most appreciated!
Share this post
Link to post
Brand: Becker
Serial: U5006497
Try 1262
Share this post
Link to post
Hey i'm looking for a radio code. MODEL No: BE 6625
                                                          SERIAL No: 25011297
Share this post
Link to post
                                                          SERIAL No: 25011297
Try 6523
Share this post
Link to post
Just had to do a window regulator assy on my 00 Boxster, and lost the code when the battery was disconnected.
CDR-220
Model: 4462
Serial No. Y5036023
Thanks in advance!
Share this post
Link to post
CDR-220
Model: 4462
Serial No. Y5036023
Thanks in advance!
Try  5149
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
