pennyporsche
35 minutes ago, Sargent said:
Need an assist please!
Becker CR220
Type 4362
Serial number 25005807
Thank you in advance.
Chris
Try 9083
Share this post
Link to post
Dears,
this is a treasure!!!
just bought today my first Porsche, a 996.2 c2 coupe.
the car was semi-abandoned as it only has 40k miles, but the previous owner had nothing from the initial documents including the radio code.
i tried three times to put a random one..... and now I only see a “Wait” message.
any ideas please?
it s a CDR22 , type 4467 and s/n 25007897
thank you I’m advance!
christos
Share this post
Link to post
7 minutes ago, ChristosP said:
Dears,
any ideas please?
christos
Try 3108
Share this post
Link to post
I have a 2002 Boxster. Had to tighten fuel tank fuel gauge. Did not know that I would have to put in code for radio after disconnecting battery. It is a Becky 1 CDR220, SN# 15007270. Does anyone have the code?
Share this post
Link to post
Try 4918
Share this post
Link to post
What is the trick on the radio when it says wait. When it first came on I tried different codes and I guess it locked. Waited hours, even unhooked battery for hours, still says "wait".
Share this post
Link to post
Please read the Lost Radio Code FAQ
Share this post
Link to post
I put the key in and left the radio on for over an hour, code screen popped up. The code you gave me worked. Wrote it down on a piece of paper and put it with my registration. Thank you very much! So much security for a CD-ROM player! Oh did I mention, who uses CD-ROM's anymore? Just us old folks that like to listen to 80's songs like "99 Red Balloons"!
Share this post
Link to post
25 minutes ago, Beale 911 said:
Please help
Porsche 911 turbo 2002
Becker
Model - BE 2580
Serial - 15096667
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Share this post
Link to post
2 hours ago, 1000miles said:
Hi Loren,
Newly aquired 996. ? Could you please help me out?
Becker CDR-210
BE2282
W5020236
Much appreciated!
Try 2641
  • Thanks 1
Share this post
Link to post
I need some help, so, I’ve replaced my fuel pump and now that the battery is back on the radio asks for the code
CDR 220
Model BE 4462
Serial # 15085927
thanks!
Share this post
Link to post
CDR 220
Model BE 4462
Serial # 15085927
thanks!
Try 7212
Share this post
Link to post
CDR-220
BE4462
25017716
Thank you.
Edited by cjbiv
just found the serial #
Share this post
Link to post
Hello,  Added a new toy to my collection, 1997 Boxster base, CR210 and I think the serial number is T5002262.  Thank you in advance.
Share this post
Link to post
Try 2469
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
