pennyporsche
48 minutes ago, Purplzzz said:
Good afternoon Loren,
Got another one:)
99 base, CDR-210
R3297
W5023906
Thank you in advance!
Try 0505
Share this post
Link to post
Hi everyone I'm new to the form as well just got a 2002 Boxster and I have a radio code but is is clearly wrong. Took the radio CDR 220 BE 625 out and this is the serial number 15007892
any suggestions what code to use? Thanks so much I truly would appreciate the help.
Edited by Birgit Miller
Share this post
Link to post
Use the procedure in the Lost Radio Code FAQ to verify your serial number. Even the tag can be wrong if the unit was ever repaired.
Use the procedure then report your (internal serial number) here.
Share this post
Link to post
5 hours ago, Tom Meloche said:
Hi Loren,
I need a code please.  98 Boxster, CR-210, model # R1996, serial # V5006488.
Tom
Try 2190
Share this post
Link to post
Hi Loren,
 I have a 2000 Boxster lost the radio codes. Not sure if this is the right place to post but I’ll try.
Becker1 cdr 220
model 4462
serial # X5029317
Thanks for any help
Edited by Horace Tyndall
Share this post
Link to post
14 minutes ago, Horace Tyndall said:
Hi Loren,
Becker1 cdr 220
model 4462
serial # X5029317
Thanks for any help
Try 5418
Share this post
Link to post
Looking for radio code on Becker CDR-220 for 1999 986. Serial number 15062232
Any help would be appreciated.
V/R
Chris
San Diego, Ca
Edited by Sawfish
Added radio model #
Share this post
Link to post
V/R
Chris
San Diego, Ca
Try 8654
Share this post
Link to post
Hello,
I would appreciate the code help on the following:
1997 911 C2
Type: CDR 210
Model: BE 2282
Serial: W5024514
Thank you for your help!
Edited by JoonSu Min
Share this post
Link to post
24 minutes ago, JoonSu Min said:
Hello,
1997 911 C2
Type: CDR 210
Model: BE 2282
Serial: W5024514
Try 5362
Share this post
Link to post
48 minutes ago, JoonSu Min said:
Hello,
1997 911 C2
Type: CDR 210
Model: BE 2282
Serial: W5024514
24 minutes ago, Loren said:
Try 5362
Thank you! Worked like a charm.
Share this post
Link to post
Can someone help me with a radio code please,
2000 boxster
Type cdr 220
Model 4462
Serial Y5040279
thank you!
Share this post
Link to post
2000 boxster
Type cdr 220
Model 4462
Serial Y5040279
thank you!
Try 6569
Share this post
Link to post
I lost the code ( PCM, phone, nav) from my Boxster from 2001.
I still have the 2 original codes (nav and pcm) but the owner added a personal code and does not remember it.
What can I do or how to reset.
It is a european car
The serial pcmnumber is PCM: 020100844
Share this post
Link to post
You did not read the Lost Radio Code FAQ ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Share this post
Link to post
I have the 2 codes but the owner added a personal code and this personal code is missing.
From Porsche and in the servicebook are  mentionned the following codes
Navi code : 1581
PCM code: 8212
Is a reset possible?
Share this post
Link to post
Navi code : 1581
PCM code: 8212
Not to my knowledge -  unless a Porsche PIWIS is used.
Share this post
Link to post
Hi Loren,  really appreciate your doing this for everyone - but now I need help.
Boxster 1998
CR-210
R3297
V5007083
Wish you the best for the Holidays !
Thx, Russ
Share this post
Link to post
Boxster 1998
CR-210
R3297
V5007083
Thx, Russ
Try 5439
Share this post
Link to post
Wish everyone marry Christmas ?
I need some help for my Navi on my car it's a boxter 2000 mod, and I just but a second hand Navi and I didn't know about the code, so now I'm stuck with nothing in my car... Could u guys pls help?
It's a BE 2580
thanks for answer!
Edited by Hemin Coplanto
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
