pennyporsche
7 minutes ago, Rufrob said:
Hello
i need help with a radio code for a used radio I bought. The dealer here in Japan won’t help
Typ: CCR2200
Model No: BE 6626
Serial No: 15000060
EC: 101
Porsche part number 996.645.127.10
any assistances will be greatly appreciated.
Try 0480
Share this post
Link to post
Dziękuje zaraz powinno sie radio odblokować więc sprawdzę
Zaraz sprawdzę ten kod jak tylko uruchomi się radio. Tu mam dokładne dane:Cdr-220 BE4462 / 996.645.126.00
W5006199
Share this post
Link to post
45 minutes ago, ascetic996 said:
Hi All -
Looking for a radio code for CDR-220; serial is Y5052653.
Appreciate the assistance in advance.
Try 4343
Share this post
Link to post
1 hour ago, Kent Richardson said:
Looking for the code for a CDR-220.
Serial Number: Y5052913
Car VIN
WP0CB29821U662216
Thank you so much in advance!
Try 8516
Share this post
Link to post
17 minutes ago, Loren said:
Try 8516
I tried the code three times with no success. The model number is BE 4462 if that helps. Are there any other codes I can try? Thank you for your help.
Share this post
Link to post
DId you use the procedure in the Lost Radio Code FAQ to get the correct serial number?
Share this post
Link to post
Yes. I used the serial number from the label on the side of the model. Radio was pulled from crashed 2001 S.  So, it is possible the VIN doesn't match the radio.  Radio SN is Y5052913
Share this post
Link to post
You can not believe the label.
If the radio has ever been repaired it got a new serial number that is only accessible through the procedure in the Lost Radio Code FAQ. Please check it that way.
Share this post
Link to post
Just checked the SN using the method in the FAQ (TP then Becker 1) and the SN shown on screen matches the one on the label. The front panel is a bit loose and so I'm going to try again while pressing the face down. Could it be that the pins aren't connecting correctly? It seems to be reading my inputs fine. Super confused.
Share this post
Link to post
Okay if the number I gave you does not work for the displayed serial number then the radio was repaired by a 3rd party (not Becker) and the serial number is unknown. I doubt even Becker can help you. Sorry.
Share this post
Link to post
Understood. Just went to go try it again but it seems stuck on “Wait” for over an hour now. I’m going to try and reinstall the CDR-210 that was originally installed. Could you help me with the radio code on my cdr-210? SN is W5021560.
Share this post
Link to post
Try 0195
Share this post
Link to post
Hello All. and I was sorry Mr.Loren.(sent to a mail to him)
Please help.I lost the code.
CR-2200
BE4466
Ser. 15020429
Thanking you in advance.
Share this post
Link to post
Hello
I am trying to find a code for my 986 2002 radio it is
cdr-22
type :4467
ser : 25010305
24/99
CDP2081
Thank you
Share this post
Link to post
CR-2200
BE4466
Ser. 15020429
Try 4938
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
