pennyporsche
1 hour ago, Loren said:
Try 9034
Will do, as soon as the stupid thing unlocks (I'm the monkey pushing buttons and the radio is stupid?)
Share this post
Link to post
And it worked like a champ.  Thank you very much!
Share this post
Link to post
2001 Porsche 911
Type: CR-220
Model: BE4362
Serial: 15031098
Thanks in advance really appreciate it!!!
Share this post
Link to post
51 minutes ago, Spliton said:
2001 Porsche 911
Type: CR-220
Model: BE4362
Serial: 15031098
Try 4178
Share this post
Link to post
On 2/8/2019 at 5:03 PM, Loren said:
Try 7594
That worked.
Thank you very much, I greatly appreciate it!!!
Share this post
Link to post
Hello
 Need help
Becker
type: cr 220
model no: be 4362
serial nr. Y5023856
ec: 113
I have allmost full code just last number is lost(last owner bad handwriting)   : 063?
tnx
Share this post
Link to post
33 minutes ago, henn said:
Hello
 Need help
Becker
type: cr 220
model no: be 4362
serial nr. Y5023856
ec: 113
tnx
Try 6520
Share this post
Link to post
1 hour ago, HelmetHead said:
Seeking code for
CDR-220
Model 4462
Ser# Y5046446
What happened to the radio and radio code I gave you last year?
Try 7269
Share this post
Link to post
Try 7269
The code worked great for that car last year.   Thank You
working on a different vehicle which had water in the floor and we swapped in a new ECU/immobilizer, ignition and door lock.     I thought I could get codes from the vehicle with our  pst2 but can't find it in the menus.   After plugging in the PST2 the radio now says *WAIT*
Share this post
Link to post
4 hours ago, Heikki Nuppola said:
Pls send me radio code for my Boxster 1997
S/N V500 7619
CDR-21
Thx
heikki.nuppola@nokia.com
Try 9216
Share this post
Link to post
Can you send me a radio code please? I have a 2000 Boxster and the radio is locked.
type 4462
seri W5005515
Edited by Fivehats
Share this post
Link to post
type 4462
seri W5005515
Try 5180
Share this post
Link to post
I have the same problem, just got a new battery and need radio code.
CDR-220
serial number:  X5035223
Please and Thank you very much!!!
Share this post
Link to post
CDR-220
Try 4932
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
