pennyporsche
11 minutes ago, Series900 said:
Loren, after a good hot fire , a replacement front harness, paint, undercoating, a donor car for all the plastic that melted. Followed With a pts2 recode to abs pump replacement, now down to Litronics and radio!
Cdr220
typ 4462
serial # 25016872
thanks!
Try 3098
Share this post
Link to post
Hello Sir
Radio type 4462
24/99
s/n. 5060026
 Hope I am doing this correctly. If not sorry
Have a good evening
Share this post
Link to post
1 hour ago, ram20 said:
Hello Sir
Radio type 4462
24/99
s/n. 5060026
Have a good evening
Try 0208
Share this post
Link to post
 Thank you Loren
Thank you thank you thank you
I now have am able to turn on my radio. But the truth is I usually just listen to the  Engine on my turbo Porsche which will sound awesome when I install my new straight pipes.
 You are a credit to the Porsche community and car lovers everywhere. A true gentleman who tolerates those of us who don't know how to follow directions.  Sorry about the email.
Thanks for your patience
Have a good evening
Share this post
Link to post
4 hours ago, ninedragons986 said:
Hi I retrieved the serial and model of my CR-210 radio
I see a model R3297 and serial number VS010652
Try 8289
Share this post
Link to post
Same problem with 2001 996. Much aporeciate assistance.
4462
Y5050937
Porsche
thank you.
Share this post
Link to post
4462
Y5050937
Porsche
thank you.
Try 4907
Share this post
Link to post
Loren you are a great asset to the forum.  Replaced battery in 2001 996 TT and I don’t have the radio code.  Greatly appreciate your assistance.
Type 4462
serial # Y5048755
Share this post
Link to post
Type 4462
serial # Y5048755
Try 1543
Share this post
Link to post
6 minutes ago, Richard Russell said:
Hello,
Could use your help.
CDR-220
4462
X5026721
Thank you for your help.
Try 4621
Share this post
Link to post
Hello,
CR-210
BE2182
T5000849
Share this post
Link to post
47 minutes ago, eima777 said:
Hello,
CR-210
BE2182
T5000849
Try 0619
Share this post
Link to post
6 hours ago, Cody Chris Collection said:
Hello, I am locked out as well my model is a:
Porsche 2001 Boxster
Becker 1
CDR-220
type:4462
ser #: 15063348
Try 7651
Share this post
Link to post
Hello, I am also locked out of my radio. I appreciate the help!
2002 Porsche 911 C2
Typ: CCR 220
Model No: BE 6624
Serial No: 15001323
Share this post
Link to post
2002 Porsche 911 C2
Typ: CCR 220
Model No: BE 6624
Serial No: 15001323
Try 6731
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
