pennyporsche
9 hours ago, Kevin Cyr said:
Looking for help ?
Type: CDR 220
Model: BE 4462
Serial: W5003070
Try 9175
Share this post
Link to post
I have a 996 with a CR 210 in it. 1999 carrera, I cannot find the card. Any help would be appreciated. The radio just says code.
Edited by vegasdriver
not enough information
Share this post
Link to post
Please READ the Lost Radio Code FAQ and follow the procedure there to get your serial number - then post your request here.
  • Like 1
Share this post
Link to post
Sorry, i could not figure out what was the tone button. got the model and SR#
CR 210
R3297
WSO 11260
thanks
left out info
Share this post
Link to post
CR 210
R3297
WSO 11260
thanks
Try 2643
  • Like 1
Share this post
Link to post
I have a 2002 Porsche Boxster.  The mechanic disconnected the battery and I need a code.  The details of the radio are:
Model - CR220
Type - 4362
Ser - 1500 1263
Thanks in advance for your help with the code.
Share this post
Link to post
Model - CR220
Type - 4362
Ser - 1500 1263
Try 2767
Share this post
Link to post
Thanks you very much for your prompt help.  I just donated money to help you maintain this site and continue to provide service
Share this post
Link to post
Thanks! :thumbup:
Share this post
Link to post
Hello !
Can somebody help me ?
I just bought a 1996 993 Turbo , radio is asking for the code and card is lost
radio type is : CR-210
radio serial number is : T5004 147
thanks you very much !
Share this post
Link to post
6 hours ago, Matt Lec said:
Hello !
Try 0920
Share this post
Link to post
Mine is a CDR-220
these are all the numbers I see after pressing the TP button.
CDP2081
type 4462
01/99
W5002872
thanks for the help.
Share this post
Link to post
12 minutes ago, Bomart71 said:
Mine is a CDR-220
CDP2081
type 4462
01/99
W5002872
Try 6838
Share this post
Link to post
PLEASE HELP!!!
I need a 4 digit code for my 1999 boxster radio.
BECKER 1
CDP2065
TYPE: 4462
SERIAL #: W5010393
Thank you in advance.
Share this post
Link to post
24 minutes ago, sam young said:
PLEASE HELP!!!
BECKER 1
CDP2065
TYPE: 4462
SERIAL #: W5010393
Try 4650
Share this post
Link to post
56 minutes ago, rwoodroffe said:
Need radio code for cdr-220
model: BE 6625
serial: 15000733
Thank You,
Richard
Try 2532
Share this post
Link to post
Hi - another newb with a code request as my first post, please...
Becker CDR-220
model BE 4462
serial X5018225
Share this post
Link to post
Becker CDR-220
model BE 4462
serial X5018225
Try 1298
Share this post
Link to post
5 hours ago, Auto TEST said:
Please code:
Becker
TYP: CDR -220
Model: BE6625
serial 25012928
Try 0871
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
