pennyporsche
One more request:
2001 Boxster Base
Becker
CDR-220
Type 4462
Serial Number: Y5053289
Many thanks!
Share this post
Link to post
54 minutes ago, CJordan said:
One more request:
2001 Boxster Base
Becker
CDR-220
Type 4462
Many thanks!
Try 2495
Share this post
Link to post
Hi, My battery got disconnected and I need a code to get the radio to work again.  Thanks
BECKER 1
Type 4462
ser:  Y5060651
Share this post
Link to post
BECKER 1
Type 4462
ser:  Y5060651
Try 8281
  • Thanks 1
Share this post
Link to post
Hi Loren,
Need your help again, got a spare from another Ebayer:
BE 4462 CDR 220
996.645.126.00
Serial number: 15088758
Many thanks!
Share this post
Link to post
13 minutes ago, Terence Law said:
Hi Loren,
BE 4462 CDR 220
996.645.126.00
Many thanks!
Try 1457
Please consider a donation to support this site - thank you.
Share this post
Link to post
Battery discharge on my 1999 Boxster.
I would really love some assistance with retrieving the code!
CDR-220
4462
X5023293
Share this post
Link to post
Hi, the battery died and along with it went the code for the radio.  The serial number is 15000686 and the type is 4362, can you please send the code?.  Thank you for your help..
Keviun
Share this post
Link to post
CDR-220
4462
X5023293
Try 2527
Share this post
Link to post
Keviun
Try 8561
  • Like 1
Share this post
Link to post
10 hours ago, JC Carter said:
Hello. Dead battery. Radio code lost.
CR-220
Type: 4362
ser#: X5017050
Thank you!
Try 5175
Share this post
Link to post
Just purchased new 996 and previous owner provided incorrect radio code
CDR-220
Model : 4362
Serial: X5010962
Edited by qtipvenom
Share this post
Link to post
CDR-220
Model : 4362
Serial: X5010962
Try 8691
Share this post
Link to post
Please help need radio code
2000 Boxster
Cr-220
Serial #5027629
Type 4462
Edited by Shayne@1992
Share this post
Link to post
2000 Boxster
Cr-220
Serial #5027629
Type 4462
Try 9296
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
