pennyporsche
27 minutes ago, J400 said:
Hello sir , I been looking to find a radio code for my 1987 Porsche 944 base model. I had a new battery in and don’t have the code if you can please help me I’d really appreciate it I’ve seen here before you’ve helped a lot others .
Becker 1
type 4462
seri: Y5042209
24/99
please and thank you . ??
Try 8460
Share this post
Link to post
4 hours ago, Loren said:
Try 6712
Will do when i get home thank you
Share this post
Link to post
Hello
i need help with a radio code for a used radio I bought.
Typ: CR2200
Model No: BE 4466
Serial No: Y5020053
EC: 112
Porsche part number 996.645.127.00
Share this post
Link to post
44 minutes ago, Kodai said:
Hello
Typ: CR2200
Model No: BE 4466
Serial No: Y5020053
EC: 112
I just gave you a code for a different radio on January 20th?
Share this post
Link to post
Thank you Sir.
The former radio had a broken cassette mechanism.
I thought I could fix it, but I bought another second-hand product.
I wish I could hear the cassette of this ...
Of course it started. Thank you for this!!
Share this post
Link to post
I just 1999 purchased 911 Carrera. radio asking to enter code.
beaker 1
type: 4462
48/98
Ser: X5024448
Can you help me please
Edited by Phil Burk
Share this post
Link to post
On 3/26/2019 at 6:47 PM, dMoses said:
Just bought a 996 Turbo and didn't get the radio manual or code with the car.
Can you help with he code?
CR-220
Becker 1
type: 4362
serial#: 15040027
24/99
worked perfectly.
Thanks Loren!
Share this post
Link to post
10 hours ago, Kodai said:
Hello
Typ: CR2200
Model No: BE 4466
Serial No: Y5020053
EC: 112
Try 0424
Share this post
Link to post
beaker 1
type: 4462
48/98
Ser: X5024448
Try 1250
Share this post
Link to post
Try 1250
This code did not work could there be another I could try
Share this post
Link to post
Did you get the correct serial number by using the procedure in the Lost Radio Code FAQ?
If not, please do so and re-submit.
Otherwise, your radio may have been repaired by a 3rd party (not Becker) - in that case I can not help you.
Share this post
Link to post
X5024428
Sorry for the type O
Share this post
Link to post
7 minutes ago, Loren said:
Try 1090
It worked
Thank you very much
Have a great day
Share this post
Link to post
In my 944S. Previous owner swap tout the Reno radio, but didn't leave me the code card.
CR-220
Type- 4362
Serial number- Y5021634
Thanks for the help
Share this post
Link to post
CR-220
Type- 4362
Thanks for the help
Try 4371
Share this post
Link to post
I could use a code if you have time.
Cr220
Type 4462
serial Y5051203
Edited by Outkasted
Correction
Share this post
Link to post
Cr220
Type 4462
serial Y5051203
Try 8602
Share this post
Link to post
Newbie here - after owning my 986 for 4.5 years, the battery failed and I discovered I don't have the radio code card. If you could help, I'd appreciate it!
Radio serial: Y5041045
Type: 4462
Many thanks!
Andrew
Share this post
Link to post
Type: 4462
Many thanks!
Andrew
Try 0170
Share this post
Link to post
Hello, I need help with a Radio Code
CDR 220
Modell: 4462
Ser. Number: Y5040535
24/99
Tank you .
Michael from Germany
Share this post
Link to post
CDR 220
Modell: 4462
24/99
Tank you .
Try 0185
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
