pennyporsche
1999 911
Becker CDR-210
Model: R 3297
Serial: V5016778
thank you for any help you can provide
Share this post
Link to post
3 hours ago, DGI said:
1999 911
Becker CDR-210
Model: R 3297
Serial: V5016778
Try 5087
Share this post
Link to post
HI- manual/code was stolen and hoping you can help with the code:
99 boxster
becker 1
serial x5021867
4462
4898
Thanks in advance
Share this post
Link to post
99 boxster
becker 1
serial x5021867
4462
4898
Thanks in advance
Try 0573
Share this post
Link to post
9 hours ago, Loren said:
Try 5087
You rock!
Share this post
Link to post
Hallo habe meinen Code bei meinem Porsche Radio verloren kann mir jemand bitte helfen.Danke in voraus
CDR22
PE 4467
Seriennummer Y5024403
Share this post
Link to post
CDR22
PE 4467
Try 7305
Share this post
Link to post
I just bought a 2000 996 Cabriolet and don't have the radio code.  It is a cr-220.  My VIN is WP0CA2998YS651092.  I'm not sure how to look up the serial number and it didn't come with a manual.  What do I need to get a code?
Share this post
Link to post
Read and follow the procedure in the Lost Radio Code FAQ.
Share this post
Link to post
Could you please help with a radio code for my 2002 Porsche Boxster s
BECKER
TYPE: CDR 220 / 4462
MODEL NUMBER: BE 6625
SERIAL NUMBER: 25013318
VIN: WP0ZZZ98Z2U644142
THANK YOU
Share this post
Link to post
5 minutes ago, cam777 said:
BECKER
THANK YOU
Try 2727
  • Thanks 1
Share this post
Link to post
Looking for a code for my 2000 boxster cdr220
serial Number Y5040608
appreciated
Edited by Moe P
Share this post
Link to post
appreciated
Try 4353
Share this post
Link to post
Hi I also need a code - 2001 Porsche Boxster S, Becker CDR-220 Radio Serial number Y5054230.  Now the radio just says "WAIT" lol.
Thanks very much!
Edited by Brunson
Share this post
Link to post
Hello,
i had to replace my battery and now the radio is locked for my 1999 911 996. I called the dealer and got the code but it has not worked. Can you please help me with the radio code
CDR-220
serial number: X5018602
48/98
GAL: 00
type: 4462
i have The VIN if it is needed.
Please help
thank you,
Edited by Cac996
Share this post
Link to post
CDR 210
BE2262
V5009143
1997 Boxster--Just bought my first Porsche and cant use the radio ?
Please help with code
Edited by Charley Belcher
Share this post
Link to post
Thanks very much!
Try 8752
Share this post
Link to post
3 hours ago, Cac996 said:
Hello,
CDR-220
48/98
GAL: 00
type: 4462
Please help
thank you,
Try 5810
Share this post
Link to post
2 hours ago, Charley Belcher said:
CDR 210
BE2262
V5009143
Try 6043
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
