pennyporsche
16 hours ago, Loren said:
Try 5810
Thank you so much!!! It worked.
Share this post
Link to post
33 minutes ago, Abhishek Birjepatil said:
Please can someone help with the radio code..
replaced the battery and stuck at this.
Serial #: X5013166
thank you guys!
4
Try 4342
Share this post
Link to post
Lost code cdr-220
tyoe 4462
serial x5029679
48/98
thanks!
Edited by Adguffey
Share this post
Link to post
49 minutes ago, Will henriquez said:
I hope you can help me with the radio code for a Becker 1, serial number 15007830, type 4462
Try 8987
  • Thanks 1
Share this post
Link to post
6 hours ago, Hotsauce664 said:
I also lost my radio code.
CDR-220
4462
X5031780
Try 2708
Share this post
Link to post
Heyyyy, lost my radio code, not written anywhere maybe you could help my Radio is CDR-210
SERIAL number is:
BE2282W5023587
Any help would be appreciated.
Thank you!!
Share this post
Link to post
Hi. New Boxster owner here. The car sat for a while with a dead battery so I need a radio code.
CDR220
Becker1
4462
serial# 15064696
thanks,
Aaron
Share this post
Link to post
SERIAL number is:
BE2282W5023587
Thank you!!
Try 1031
Share this post
Link to post
CDR220
Becker1
4462
serial# 15064696
thanks,
Aaron
Try 4801
Share this post
Link to post
On 4/12/2019 at 11:51 PM, Loren said:
Try 1031
Thank you very much! It worked!
had a separate issue, radio turns off when car is running.
Share this post
Link to post
CDR-220
4462
15077135
Share this post
Link to post
Hello,
I've locked myself out changing the ignition switch if someone could please help :)
CDR-22
4467
serial: 15004793
24/99
Thank you!
Share this post
Link to post
16 minutes ago, 4StringBass said:
Hello,
I've locked myself out changing the ignition switch if someone could please help ?
CDR-22
4467
serial: 15004793
24/99
Thank you!
Try 9161
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
